3vze complete exhaust
Old Mar 31, 2010 | 01:26 PM
  #301
91_TOYOTA_4x4's Avatar
Originally Posted by MaK92-4RnR
Omfg jason you clown. lol obvs if i get it smogged and take the cat off i'll have to replace the O2 sensor again in 2 years. do you know how much o2 sensors are?
dude o2 is like 150 ish not bad evey 2 years and its not because of you cat, its you header down pipe because its father from the engine??? so just gut a cat for after smog you clown mike hahaha
Old Mar 31, 2010 | 01:36 PM
  #302
Wrenchinjoe's Avatar
If your CEL is on do you fail the emissions test even if it passes the visual test and sniffs clean? Assuming the intermittant CEL won't fubar the test, they do make O2 simulators to generate the resistance required to placate the ECU. I have not tried one of these so don't take my word for it, but they are supposed to cure CEL's. It would be easy to swap that out prior to your emissions test, then reinstall it.
http://www.amazon.com/Magnum-Adjusta.../dp/B001CZOQKM
Old Mar 31, 2010 | 01:38 PM
  #303
Wheelingnoob's Avatar
I believe in Cali as here they have mobile smog trucks that have cameras that can tell if the cat is working right or not. Once AirCare is done in 2011 we will be seeing a bunch more I think (in BC).
To the OP if you put in a high flow cat you will still pass smog and also free up a bit of the bottleneck you have in the stock cat. If you do not, just leave it in and enjoy the sound of the truck as is. Getting rid if the cat and straight piping is pointless I would rather lose 2-3hp and have it then have that power and be doing my part to ruin our environment.
91_TOYOTA_4x4 call Toyota and see what a new O2 is going to cost you...bet its a lot more than $150.
  #304
MaK92-4RnR's Avatar
if the CEL is on I will fail emissions test no matter what. they wont even look at the vehicle, as it is the first.
Old Mar 31, 2010 | 10:07 PM
  #305
well i had a new o2 put in and it was 180...
Old Apr 1, 2010 | 05:55 AM
  #306
Somebody correct me if I am wrong, but isn't the ECU looking for some range of resistance from the O2 sensor? i.e. If the resistance is within the desired range, the CEL stays off. If that is correct, couldn't you add a resistor between the O2 sensor and the ECU in some 'discreet' location to keep the CEL off?
EDIT: Jay, ... ahh yes grasshopper, now I more fully understand... thanks for the education.
Old Apr 1, 2010 | 09:38 PM
  #307
Jay351's Avatar
The engine uses the input from the o2 sensor to figure out what fuel adjustments it needs to make. If you throw a resister inline to the ecu then it will get false info.
If its bad, replace it?
Old Apr 1, 2010 | 09:40 PM
  #308
Jay351's Avatar
Originally Posted by Wheelingnoob
Mine too is under the drivers seat on the down pipe. The idea that running with out a cat will kill a pre cat O2 sensor is not correct.
You can get magnaflow high flow cats for $90 that will pass smog (we have the same dyno smog test here) and I have passed with no problems.
My $100 SS magnaflow has passed the smog tests going on three years so far..
Old Apr 2, 2010 | 07:05 AM
  #309
BeenYota's Avatar
Mak - What is the numeric code you are getting? If pre-cat 02, have you checked to see if the continuity is good? Maybe there is a poor contact which would make it intermittent. Maybe its just plain dirty due to carbon build up. Opening your engine a bit more with your headers may have sped this process. If you're short on cash, you could try cleaning the O2 sensor with a product called deep creep which is made by sea foam. I've read this has worked on O2 sensors with limited success, however cleaning an O2 sensor in any way shape or form is usually last resort. Replacement is likely the best option.
For the record my 92 has only the pre-cat however with intake, headers, glass-pack/exhaust I am flowing pretty good and have not yet blown any codes related to O2.
Hope this helps,
Ben
Old Apr 2, 2010 | 08:36 AM
  #310
MaK92-4RnR's Avatar
Hope this helps,
Ben
honestly, I have NO history of my truck EVER being tuned. i bought it at 107k miles and I seriously think it has only had its timing belt changed either never or once. ( it just broke 143 now ) the o2 could be preplaced and that might help it. but it never came on until I did the headers.
Old Apr 2, 2010 | 08:58 AM
  #311
BeenYota's Avatar
No $h!+.. bummer dude. Do you plan on doing the work yourself? If so, take some pics. I think the timing belts are recommended every 60K or so. Mine isn't due but, I plan to change it anyway before winter (October) when I do most of the seals. I'm very confident you can take this on yourself if you did your own headers.
Old Apr 3, 2010 | 01:13 PM
  #312
lol my check engine light just came on last night uhhhhhhh frickin toyota's man
Old Apr 17, 2010 | 03:22 AM
  #313
LDL's Avatar
LDL
I've been reading this thread , getting part number's and such , getting ready to put header's on my 94 4runner. Came up with a different part number than what was posted. New number for the header's I found is THY-505 , from www.dougthorleyheaders.com .. so going to look for gasket set right now .
Old Apr 17, 2010 | 09:07 AM
  #314
calipatient's Avatar
LDL: I can get ya a way better deal than you will get from their website. and yes, thy-505 is the same kit i got. long tube headers. the kit comes with the 3 gaskets you will need. if you want the phone number to save ya at least $100 lemme know!
Old Apr 18, 2010 | 04:30 AM
  #315
LDL's Avatar
LDL
Calipatent : Sure , everyone is alway's looking to save some cash, just post it up , or email or private message me : txharley10@hotmail.com
Old Apr 20, 2010 | 07:09 AM
  #316
BeenYota's Avatar
While you're building ideas of your header/exhaust systems - make sure you take a look at VHT FlameProofing. It's great stuff to use BEFORE installing.
Old Apr 26, 2010 | 10:00 AM
  #317
MaK92-4RnR's Avatar
update: the CEL light has not been coming on ever since the weather has been 80+ degrees. lol
Old Apr 26, 2010 | 02:02 PM
  #318
lol good news dude same with mine, we just had a few hot days and my truck ran so good when it was hot, even though my afm in done lol toyotas must love being cooked
Old Jun 15, 2010 | 02:39 PM
  #319
Brhesson's Avatar
looks great, about to do similar
got Downey headers from ebay (original co-owner sells on there) and rebuilt the 3vze, got tons of time in it but little money so i'm trying to do it all when stuff is easier to get to. Got the Heads and lower intake on and about to install the headers, then belts, upper intake, new Optima battery, new cables, new stereo, new spkrs, blah blah blah. Thanks for the helpful info and links.
Old Jun 16, 2010 | 05:22 AM
  #320
BeenYota's Avatar
Brhesson,
How much did you pay off the bay? ceramic? Take a picture of what you went with. I'm anxious for you to see how things turns out. Thats badass.
