3vze complete exhaust
#347
haha you should just do it! do a 3" front and make the front hanger up higher and shorter shackles, low profile bump stops and run your 33"s
. like Vance said when he sas'd, he could just point it somwhere and it would go right over it without lockers even :O will be so sick haha
#348
hey guys i had a question, is there any flex pipe on the 505s? iv been waiting for mine for 2 and a half months now. And still not sure when they are going to arrive. Last thing i heard was they were waiting on flex pipe..
#349
glad to see your willing to learn and do your own wrenching even though your not that experianced, its a great thing to learn and there is nothing like doing your own work. Don't mind kawasaki his hour exhaust system probably consists of a dryer vent hose and some pvc. my compliments man, keep up the good work
#350
lol Kawasaki is a RL friend of mine. Has been since i was like in 10th grade. I know he's just bustin my balls, so no biggie.
Heres a small update:
3 of the headbolts backed out yesterday! I had them replaced with factory head bolts but man, the exhaust leak was massive... Had to replace the gasket too as they were burned up. Valves are fine as well
#351
hey man i am doing this install right now and i have come to the part of connecting the reed valve to the headers and its not lining up at all so i guess im just wondering if you had a problem with this and if so how did you do it. thanks in advance
#354
the copper tube is straight junk... but the only way to get it to work is unbolt the reed valve, put the reed valve on the copper tube, and call it good. the valve will be loose at this point, but it'll be functional still. the only way to get it to bolt to the block, is to get a flex hose like the EGR valve.
#359
ok so i took your advice about unhooking the reed valve so now its just hanging there it looks like it should be good so thanks for that. i have one more ? though, did you have any problem with the piece of exhaust pipe with the o2 sensor hole in it the flange to bolt on the o2 sensor is welded off center so that the nut will not screw on to the bolt , it might just be mine so im going to call and see if they will send me a new one. i hope they do
#360
elk, i had the same probs your talking about. For the o2 sensor, i just ground down the side/corner of one nut so it would slide in far enough for the bolt to thread thru. Also works to hold the nut so you only need 1 wrench to tighten
next year if i go 3.4 its getting full exhaust and that borla
