3vze acceleration problem
Old Oct 16, 2013 | 08:40 PM
92yotadx's Avatar
Unhappy 3vze acceleration problem
I have a 1992 pickup with the 3vze. i just changed the valve cover gaskets because of bad leaks and now when i go to take off the rps climb like normal but the truck doesnt move until it gets so high and then it jerks and then takes off. idle is the same as it was and everything seems good it just hesitates now. thanks in advance for answers. automatic transmission btw.
Old Oct 16, 2013 | 09:26 PM
scope103's Avatar
Check the connection to the engine coolant temperature sensors at the back of the engine. The transmission will not go to lock-up when cold, and if you knocked a sensor connector loose (they're close to the valve cover) you might have the problem you (sort-of) described.
Old Oct 16, 2013 | 09:37 PM
92yotadx's Avatar
ok thanks i will check it. also once i get moving it shifts and accelerates like normal.
Old Oct 16, 2013 | 09:56 PM
92yotadx's Avatar
if the ect sensor was unplugged wouldnt my coolant gauge on the combo. meter stop working also?
Old Oct 17, 2013 | 06:43 AM
scope103's Avatar
No. There are four temperature sensors (CSI Timer, ECT, gauge, and transmission).
Old Oct 17, 2013 | 11:38 AM
Gamefreakgc's Avatar
Sounds like it could also be the TPS if not the ECT. If that was bumped and moved, it would think that the engine is in "idle" until the throttle plate opens up a lot. If you stomp on the accelerator, does it still hesitate?
Old Oct 17, 2013 | 01:01 PM
92yotadx's Avatar
the ect is plugged in and the harder i accelerate the worse the hesitation is.
Old Oct 17, 2013 | 01:04 PM
92yotadx's Avatar
its like its not engaging into drive or reverse. you put it in drive and it doesnt engage then when it gets some rpms it engages.
Old Oct 17, 2013 | 02:15 PM
oldblue's Avatar
check the tranny fluid level.
Old Oct 17, 2013 | 02:44 PM
92yotadx's Avatar
thats the first thing i did. its good. also seems like the warmer it gets the less it hesititates. its much much worse when the engine is cold.
Old Oct 17, 2013 | 08:27 PM
92yotadx's Avatar
bump.
Liadrin
Apr 25, 2022 02:54 PM
Sleaker
Aug 26, 2020 06:03 AM
Liadrin
Sep 1, 2015 06:44 AM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
