3VZ Rebuild
Old Sep 16, 2010 | 03:12 PM
  #261
camo31_10.50's Avatar
only pic i took...just shows my EGR crap gone
i'm going back down to the shop now to solder on my "new" injector plugs..and the plug to my cold start injector time switch thingy...lol
after that..upper intake goes back on.
motor mounts get tightened all the way up...(don't ask)
starter gets tightened down...exhaust gets "installed" (just my downpipe and the driverside downpipe)
plug everything up...oil cooler needs to be cleaned and installed as well......almost forgot about that.
Old Sep 16, 2010 | 03:13 PM
  #262
DO NOT ASK ME ABOUT MY WIRING HARNESS........i have NO idea why it looks like it does..
i, however, am going to wrap it all up good
Old Sep 16, 2010 | 09:11 PM
  #263
well i got it pretty much back together lol
tomorrow evening i will start plugging the rest of the vacuum hoses/wires up...and double check everything
Old Sep 17, 2010 | 07:21 AM
  #264
BackGateYota92's Avatar
ya man i like the cherry bomb extremes. i actually have to go buy one today cause my dang school pulled my parking privaleges until i get a muffler put on. lol but ya either of them choices would sound good
Old Sep 17, 2010 | 08:06 AM
  #265
LMAO yea my school had a problem with the exhaust on my '80 4x4 (20R). all i had on it was a Header...nothing else lol sounded like a tractor lmfao
i think the Magnaflow will give the better sound..so i think i'll order one of em here pretty soon..might just have him run straight pipes until i get the muffler lol
Old Sep 17, 2010 | 10:03 AM
  #266
there ain't a problem with that. lol
Old Sep 17, 2010 | 12:26 PM
  #267
yea lol
it'd just be UBER LOUD AND ANNOYING lol
i mean, i drive a 1996 dodge with straight pipes (no cat, no muffler) and it's LOUD..but it's very annoying lol.
sooooo wish i could go home and start on it right now...but alas i have to meet a girl at a football game tonight
Old Sep 17, 2010 | 01:02 PM
  #268
haha just a friday night in dixie man. lol went mudding yesterday and spent all day cleaning it for tonight. lmao
Old Sep 17, 2010 | 01:09 PM
  #269
hahaha i remember those days LOL except we didn't clean our trucks.
Cruise night saturday night! hope to have it ready to go by then going to trailer it over there (~10 miles) and cruise a little bit, then trailer it back.
i am however hopefully going to start the break in procedure though.
  #270
on the topic of Break In Procedure....anyone got an idea or link for the best way to break in this beast?
i'll likely be breaking it in with some Castrol 10w30 Dino oil...any additives i can put in it to make things better?
for INITIAL start-up...what should be done?
I kinda jumped ahead of myself.
for Break-in procedure..i was going to stick with the driving it normal method..don't rev pest 4000rpm..don't stay at idle/constant rpm for very long. bring it up to around 3000rpm in every gear..and let of the gas, allowing the motor to slow itself...that pretty much it?
I do still need info for the Initial startup...i'm not going to buy some royal purple break in oil for this either lol it's too expensive and can't get it until next week.
i figured just throw some cheap 10w30 in it..fill up the oil filter and oil cooler(maybe?).
I DID NOT PRIME THE OIL PUMP....as in the oil pump is dry....if i could prime it now (the motor is in the runner) then i would...but i can't.
Old Sep 17, 2010 | 09:13 PM
  #271
i have yet another picture
things that still need to be done.
Oil cooler, cleaned and bolted on.
thermostat.
starter tightened up.
passenger side motor mount tightened up (after starter)
slave cylinder replacement.
put on the fan.
belts.
radiator.
fan shroud.
oil filter and Oil.
coolant.
and then after i do ALLL of that, i have to figure out why it won't start..because it wouldn't start when i pulled it into the shop..so i don't expect it to this time.
i have a thread on that..i think it has to do with my alarm.
Old Sep 18, 2010 | 08:09 AM
  #272
Terrys87's Avatar
You are on the downhill side of getting back together. Maybe you fixed the problem when you put everything back together. looking forward to seeing you get this running. Hang in there.
Old Sep 18, 2010 | 10:29 AM
  #273
yes i'm definitely on the downside, right now i'm trying to find a slave cylinder and a thermostat..lol
i think solving the problem of it not starting is a whole other mountain itself
Old Sep 18, 2010 | 11:46 AM
  #274
well if no one will chime in...i'm just going to do the initial start up with some crappy walmart SuperTech oil and a fram filter...let it run for a few minutes..maybe get it up to operating temp? shut it off..drain the oil, put a new filter on, put some Castrol 10w30 in..run it for the first 500-1000miles...do next oil change with Castrol and a better filter.
Old Sep 19, 2010 | 02:42 PM
  #275
Terrys87's Avatar
So have you got it all back together? You havent updated it, Let us know how it is going and if it starts up all right.
Old Sep 19, 2010 | 03:55 PM
  #276
i haven't updated because i keep coming up short on tools or parts.
wish someone would chime in on the initial start up/break in.
Old Sep 20, 2010 | 09:31 PM
  #277
jeez what happened to everyone that was following the thread?
i have to get a new clutch line....the one that goes down to the slave cylinder (the hard line.)
gonna get it off a junkyard runner tomorrow...after that...i need to clean out my oil cooler :/
Old Sep 21, 2010 | 06:13 AM
  #278
skypilot's Avatar
http://www.flickr.com/photos/9083490...7602888026197/
If its lifted; may I suggest a Russells -3 line one 90 degree bend and one straight on a 3' length, with 2 adapters and a bulkhead kit.
Just put one on mine and it took me a while to figure it out due to the 4" body lift.
Old Sep 21, 2010 | 12:01 PM
  #279
i went and grabbed a stock line from the junkyard..gonna put it on later tonight thanks for the info though! i'm sure someone else can sure use it!
Old Sep 21, 2010 | 12:12 PM
  #280
91_TOYOTA_4x4's Avatar
hey camo is this thing running yet? lol
