3" body/drivetrain lift. New Driveshafts or not?
Old Feb 28, 2008 | 11:02 PM
grayguy's Avatar
Ok, I am interested in doing a 2 or 3 inch body/drivetrain lift. I'm just wondering, are new drive shafts required to do this? I searched for a while and couldn't find an answer. I think this is by far the most cost effective way to get some good clearance for IFS trucks.
Old Feb 29, 2008 | 05:50 AM
WFO's Avatar
WFO
Without any other suspension lift your stock ones will be fine. At least the rear one.
Someone else should be able to tell you about the front.
Old Feb 29, 2008 | 06:23 AM
stupid_mud_gremlins's Avatar
If You're doing a body lift you shouldn't need to change your drivetrain at all, doesn't just the body move up off the chassis?
Old Feb 29, 2008 | 06:26 AM
grayguy's Avatar
...true, if you are just doing a body lift...that's not what I'm talking about. The only reason i want the body lift is so that I can also lift the whole drivetrain and gain lots of clearance under the center of the truck. It's pretty common.
Old Feb 29, 2008 | 06:49 AM
rhino66549's Avatar
What do you need to do to raise the drivetrain?
Old Feb 29, 2008 | 07:00 AM
4Crawler's Avatar
I didn't have to change anything when I added a 2" drivetrain lift to my '85:
- http://www.4crawler.com/4x4/CheapTri...ft/index.shtml
All depends on how close your shafts are, lengthwise, at the present time. As long as you have sufficient slip yoke spline engagement, should be fine.
Old Feb 29, 2008 | 08:19 AM
grayguy's Avatar
Motor mounts and T-case crossmember, and hopefully not lengthen the driveshafts
Old Feb 29, 2008 | 09:03 AM
Chrisnxl185's Avatar
so do you have to cut the horse collar crossmember out if you don't have dual t cases?
Old Feb 29, 2008 | 09:07 AM
4Crawler's Avatar
Measure and see:
http://www.4crawler.com/4x4/ForSale/...l#Introduction
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
Redeth005
Jun 28, 2018 08:16 PM
ZGjethro
Jun 7, 2017 11:04 PM
Brodetski
Sep 30, 2015 11:50 PM
