ok this might be a dumb question but was the first pic you posted of the 4runner stock hieght?? and what size tires were those??
Quote:
Did you not read the previous posts in this thread before making asking?Originally Posted by afnf_life
Quote:
33x12.50 minor rub, to wide for our light trucks
33x12.50 no lift
Originally Posted by SR5
33x10.50 no rub, and what i recomend 33x12.50 minor rub, to wide for our light trucks
33x12.50 no lift
NOOB QUESTION!
So, what is backspacing?
Also I wanted to put on 1.5" BlowJob spacers up front on my second gen. and landcruiser coils in the rear.
How much of a lift do the landcruiser coils give?
Also, I want to put 33" tires on my truck after this little lift, but I was wondering if 35" could fit without doing anymore lift and without mauling the fenders? (I'm only asking because I'm confused about what backspacing is).
Thanks
smod
Thanks
smod
Thanks
smod
my cruiser coils gave 3.5 inches of lift. 35's def won't fit with no more lift. If you do just the BJ spacers upront, you may need to trim the pinchweld to stop rubbing. and this website will explain the backspacing.Originally Posted by SMOD
NOOB QUESTION!So, what is backspacing?
Thanks
smod
Ok. So 3.5 inches in the rear and 1.5 inches up front. Hmm. Well my 4Runner's rear sags some so maybe it will work out to be pretty even? Do you think?
I think 33's would be big enough for right now anyway. So that's fine.
What is the pinchweld? I'm assuming it's a weld on or near the front fenders. ??
And I don't see a website to explain the backspacing.. Maybe you didn't type it.
Thanks
Thanks
Thanks
sorry i forgot to add the site, heres one explaining the pinchweld http://www.customtacos.com/tech/index.php?article=9Originally Posted by SMOD
Ok. So 3.5 inches in the rear and 1.5 inches up front. Hmm. Well my 4Runner's rear sags some so maybe it will work out to be pretty even? Do you think?I think 33's would be big enough for right now anyway. So that's fine.
Thanks
and heres the one for the backspacing http://www.getahelmet.com/jeeps/tech/backspace/
with the cruiser coils and bj spacers my 4runner sits with the front 1 inch lower, if you want you can crank the torsion bars too, to level it. but i don't mind the little bit of nosedive it has.
Alright awesome.
Those sites really helped. Thanks a lot.
I don't want to crank the torsion bars. I've decided against it because it's just too risky for me.
1inch lower in front isn't too bad. But I dunno if I could live with that. lol. I'm picky.
Something else I've considered is doing coil spacers(I rather not). but I think it might be ok.
If I have a saggy rear end and I put on 2inch spacers and 1.5inch spacers up front.
Judging by what you said about the landcruiser coils maybe it would be 1/2inch lower in the rear?
I know it's not right comparing it this way. I'm just trying to get an idea.
Also, the cruiser coils probably vary depending on how much spring they have? correct?
i guess with the spacers it would probably be like that depending on how much yours sag. The cruiser coils i'm pretty sure all give around the same amount of lift. the 1 inch difference is pretty much unnoticable unless you point it out. this is what mine looks like.Originally Posted by SMOD
Alright awesome.Those sites really helped. Thanks a lot.
i don't know why but that one it looks like its lower in the back, but it's not
another one
another one
Ok. I did some thinking.
I was wondering if anyone had a pic of a 2nd gen. 4Runner that has 1.5 inch BJ spacers up front, Cruiser coils in the rear, 33x12.50 tires, and some type of wheel spacers (like maybe 3 inches).
I was also considering just lifting the front with the spacers and leaving the rear coils stock and have 33x12.50 tires with 3 inch wheel spacers. Anyone have a pic of that??
Spacers for the rear coils just doesn't sound appealing to me, but I really don't want to get a 3-4 inch lift with the cruiser coils in the rear and 1.5 inches with bj spacers up front... I'm worried that the difference will be worse than a 1 inch difference. A 1 inch difference probably wouldn't bother me too much.
Thanks
Smod
Thanks
Smod
with 3" wheel spacers, you're going to get major rubbing on the front fender, not to mention, your rear tire won't stuff into the fender. I have the setup you are talking about but with no wheel spacers and the rear just barely misses the fender when it goes to stuff in there. Any wider and my "stuff" flex in the rear would be much more limited as it would hit the fender.
Here's a pic, there's room for an 1" spacer mayber
My rims have 3.75" backspacing (which is pretty common for 15x8 aftermarket rims)
Quote:
First off let me explain that you do not need a lift kit to fit 33x10.50 or 33x12.50. the 10.50 will fit with no rub at all, while the 12.50 will fit with some rub, backspacing will help take care of that rub
example:
Also you can do a body lift for Farly cheep
Example with 2" body lift
Old Man Emu lift kit options
Option (1)
2"-3" Lift (approx.)
Sdori 1.5" Ball Joint Spacers (1pair)
Sdori 2" Coil Spacers (pair)
OME N98 Front Shocks (each)
OME N71E Rear Shocks (each) FJ80 Shock
OME 901HD Coil Springs (each)
OME SD33 Steering Stabilizer
Total $638.65
Option (2)
1.5"-2" Lift (approx.)
OME N72F Rear Shocks (each)
Total $501.24
Option (3)
OME N72FRear Shocks (each)
Total $454.72
Example of 2" OME lift
2" 4Crawler lift
1.5 BJ spacers and 2" coil spacers $189.00
1.5" BJ spacers and 80 Series Land cruiser coils
80 series land cruiser (1990-2008)
*lift 3" * Also If you get them of a truck, they come one short sided one long, just the way they are, so try to get a pair of short sided, or longer sided, only about 1/4" difference
Example with of 1.5" BJ spacers and 80 Series Land cruiser coils
80 series land cruiser on 33x12.50
4-5" Rough Country lift $609
*Now this is meant for an 86-96 4wd IFS Pickup, however all you need to do is replace those blocks with 80 Series Land cruiser coils.*
4" Trail Master lift $1,642
*Notice it would have coil springs for the rear, not blocks*
4" Procomp lift $1,373
Example of 4" and 33x12.50
If their is any i forgot, or you think i should edit something let me know.
pics and specs of more yota!! https://www.yotatech.com/forums/f116...r-yota-155366/
Hey thanks for all the info. I wanted to put 33 10.50s on a factory 95 4runner with the factory susp and wheels, and do a 2" lift down the road. Will this work, i read the info you gave but just wanted to be sure, as i spoke to a local guy that says it wont work. Thnks, MatOriginally Posted by SR5
I did some research on what type of lift kit i wanted for my truck, and i rang into a lot of lifts, so i thought id post them, as a helpful guide for beginners First off let me explain that you do not need a lift kit to fit 33x10.50 or 33x12.50. the 10.50 will fit with no rub at all, while the 12.50 will fit with some rub, backspacing will help take care of that rub
example:
Option (1)
Total $638.65
Option (2)
Total $501.24
Option (3)
Total $454.72
2" 4Crawler lift
Quote:
Thanks
I think it will look funny. They already have the squatty rear look without lifting the front. There are other options for lift coils if you don't want to go as tall as cruiser coils. OME, Downey, etc.... I'd probably go with one of those, but you'll have to figure out which one you want.Originally Posted by SMOD
ok. sweet. So what do you think about not lifting the rear?Thanks
Yeah. I thought it would look funny too but it would help wheeling a bit..
Do you know anything about the OME or Downey coils?
Thanks
Thanks
from another thread.
Quote:
Before with 32s:
After cruiser coils and bj spacers
Originally Posted by s_wall98
Heres some more.Before with 32s:
I know this has beat to death but would the landcruiser coils require new shocks or extended brake lines?
Thanks
Thanks
ok i need some help i want to lift my 90 4runner with the bj spacers and the fjcoils can ypu tell me exactly what i need so i dont end up with the wrong stuff and a ballpark price.
thanks, chris
thanks, chris
