22re timing set at +15 degrees?
Old Mar 2, 2007 | 06:39 AM
mtrdrms's Avatar
Is this normal? I just got my engine to run and when I checked the timing it is +15 or so? It seems to idle fine.
Old Mar 2, 2007 | 07:49 AM
Yota82's Avatar
Did you jump the diagnosis port prior to checking the timing?
Old Mar 2, 2007 | 09:58 AM
rdlsz24's Avatar
You should be set to 5 degrees BTDC with the engine warm and diagnosis port jumped.
Rob
Old Mar 2, 2007 | 12:31 PM
mtrdrms's Avatar
I did not jump the diagnostic port. Will do and recheck. Thanks.
Old Mar 2, 2007 | 05:16 PM
foot0069's Avatar
FSM says should read between I think 10 & 13 with jumper out at idle
Jim
noahstancik
Jul 10, 2015 11:18 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
