Is the 22RE that gutless??
Old Jan 28, 2006 | 07:44 PM
farmerj's Avatar
Not sure about Lunnzz,
I have 4.11's and 31/10.50's I think it's my biggest contributor to low power.
Looking at going to 30/9.50's next time I get tires.
Old Jan 28, 2006 | 07:52 PM
4Crawler's Avatar
Yep, you are about 10% over-geared with that size tire (28" is stock). Your biggest "bang for the buck" would be to swap in a set of 4.56 gears from a junkyard. You would get a real 10% increase in torque to the road plus better fuel mileage and your speedometer would read correct as well.
Old Jan 28, 2006 | 07:56 PM
InternetRoadkill's Avatar
The stock 22RE is not a powerhouse, but it's decent. At 144 cubic inches, it should be making around 140 to 150 HP by today's standards. But alas, it's producing only 115HP +/-. I'm re-camming and upgrading mine to get a little more energy from it.
You might check the obvious stuff: compression, EGR valve, timing, cat converter, air cleaner, etc. to see if something is holding it back.
Old Jan 29, 2006 | 05:26 AM
Lunnzz's Avatar
Truck is stock except the 31x10.5x15 tires. Not sure about the gears they are what ever stock is. I was thinking about the cat last night. I'll try to check it out today. And I know the 22re is no power house mine just seems to be losing power.
Old Jan 29, 2006 | 06:47 AM
  #25
seaflea's Avatar
You may want to adjust the valves. if they are out of adjustment, you will be down on power. I would try that first.
Old Jan 29, 2006 | 06:56 AM
  #26
Lunnzz's Avatar
I am going to do that also I can hear them or what seems to be the valves my buddy is gonna let me use his feeler guage I just need to get a new valve cover gasket. I'll try that next weekend.
Old Jan 29, 2006 | 07:38 AM
  #27
farmerj's Avatar
I would tend to agree with you except for three things:
With my axle code of G292, I know my speedo should be off.
When I run it against a stop watch and a measured distance, The speedo figures correct.
When I run it against the GPS, it reads correct.
When I run it against those radar machines the local LEO put up. It reads correct.
Does anyone know what gear goes into the transfer case for the speedo? I suspect, someone put a different gear into it. But I need to know what they are.
I adjusted my valves as well last fall. Mainly for a tick in the valve train. Glad I did too. The #1 and #3 exhaust were way loose.
One other thing I found helped a lot last year, change your gear oil. Mine were no longer lubricants, they were sludge. I had to change them twice to get decent looking fluid to come out.
I can now hold speed in 5th gear and in December pulled a 2500 lb tandem axle trailer 200 miles in 4th gear. Still got 15mpg with it. This was before I messed with the air valve on the throttle body. It's not the idle speed screw on the throttle cam either.
Old Jan 29, 2006 | 07:46 AM
  #28
4Crawler's Avatar
Speedometers can be off, often enough to make them "correct" with tire size or gear changes. For example, I have 4.88s and 33" tires, my odometer is correct to less than 1% error. My speedometer is off about 7-8% (reads 70 when I am going 65 per the GPS). Both speedo and odo are driven off the same gear and cable.
Yes, the speedo gear could have been changed (I think the stock gear is something like 16 teeth, but I don't know for sure), or the axle gears may have been changed by a previous owner, or it is not uncommon for the axle code to be incorrect. The real answer to what ratio you have is to get a tooth count on the gears or do the wheel/driveshaft spin test.
Old Jan 29, 2006 | 05:02 PM
  #29
84sr5yoty's Avatar
Originally Posted by farmerj
I am also having issues with the temp pegging out and then coming back to normal temp. I believe it's just a bad t-stat, just haven't gotten around to changing it yet.
Temperature gauge overshoot. Common problem with the 22re. Get the dual valve thermostat.
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old Feb 2, 2006 | 06:16 PM
  #30
ayoung101's Avatar
Originally Posted by Lunnzz
I'm running 31"s rest is stock. I didn't think they'd make that big of a difference if so maybe I need to re-gear it. It is kinda dangerous I was merging and it don't hardly have enough power to get up to speed to get on the highway. Good thing is I don't drive it on the highway much.
i drive daily through the freeways in downtown detroit with my 22re with 31" tires and no regears. i can get 80+mph and keep up with everyone in the fast lane. course, with the way that i drive, it's no wonder that i'm lucky to get 15 mpg!
Old Feb 2, 2006 | 06:28 PM
  #31
bob200587's Avatar
4.56s woudl be wise, thats what I'm looking towards. Just gotta save up and do E-locker and Trutrac at the same time.
Old Feb 2, 2006 | 07:04 PM
  #32
Lunnzz's Avatar
I'm in the same boat as you need money. I was talking to a friend and he also suggested 4.56 gears so I think eventually thats what I'll go with.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
