22RE engine stumbling....
Old Jan 8, 2007 | 07:29 AM
4Cor's Avatar
Thumbs down 22RE engine stumbling....
Hi,
New to the site, so I figured I'd get the ball rolling with a question....
I've got a 22RE engine ('87 4Runner). It's a re-man engine installed shortly before I purchased the truck. It tends to stumble a little. That's the only way I can describe it. It's far more common when the engine is not under load like when I'm cruising along at 2500 RPMs or when I'm backing off the throttle. Under hard acceleration there's no issue, or at least it doesn't feel like there is one.
So far I've:
* replaced plugs, wires, cap, igniter, fuel filter
* changed the engine octane setting and started using premium
* had a compression test done (all 4 are well within factory spec)
It's more of a nuisance than a problem, but I'd love to get it corrected all the same.
Any thoughts or advice greatly appreciated!
Cheers,
Cory
Old Jan 8, 2007 | 07:38 AM
ricoace's Avatar
I just posted a thread with the same type of problem...however, I had a similar problem before and it ended up being that my idle mixture settings were wrong... get the book and look at what your setting should be for your truck...should be a label under your hood with that information.
Old Jan 8, 2007 | 07:40 AM
4Cor's Avatar
Thanks ricoace. I'll check that out for sure.
Would that account for the problem at any rpm other than idle though?
Old Jan 8, 2007 | 08:00 AM
ricoace's Avatar
My problem sounds the same as yours, the only time I noticed it was at stops(lower rpms) When I hit the gas to move it would stumble and very little power, until I got going again, and it seemed to run fine. It was my idle adjustment. I didnt have a tach, so what I did, I turned the adjustment down at idle until the engine just ran like crap! Then, I made small minute adjustments, let the engine stabilize after each adjustment and using the throttle linkage to rev the engine to check my results...it worked.
And wait for engine warm up before you start making adjustments.
Your welcome, hope it fixes it.
Old Jan 8, 2007 | 08:02 AM
4Cor's Avatar
Much appreciated! I"ll definitely be giving this a shot.
BTW, I don't have a tach either (just guessing based on engine sound and what that translates to on other vehicles) so your advice on approach is particularly useful.
Cheers,
Cory
Old Jan 8, 2007 | 08:06 AM
waskillywabbit's Avatar
My 85 did that and it was the TPS.
Old Jan 8, 2007 | 08:10 AM
ricoace's Avatar
Cheers????? Your in England Am I right? (smile)
Old Jan 8, 2007 | 08:12 AM
4Cor's Avatar
Canada actually. ;-)
And thanks waskillywabbit, I'll check out the TPS too!
Old Jan 8, 2007 | 08:14 AM
ricoace's Avatar
ooops...thats right! LOL
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
bryan34w
Jul 6, 2015 05:53 PM
