22RE broke a timing chain guide
Old Aug 28, 2009 | 10:26 PM
davo247d's Avatar
So here is the story, my 22re broke a timing chain guide so i put a new one in. Later that day it was idleing like at 500 rpm i knew my timing was off cuz i was having a hell of a time with the distributor so i left it so i could get to school in the morning. but here is the thing i tryed for hours to get the distributor right and i was useing my timing light and the timing notch was way off it was way on the left side of the timing marks so i ajusted it twards 5 degrease and it ran worse so here is my question
-would oil presure have any thing to do with it?
-did i screw somthing up?
-do my valves need to be ajusted
(and off the topic)
-would i have to redo the stop valve train to put in a 268 rv cam from engnrebldr
- also would a chip thing from ebay really help i think its a utp?
so if anyone could help or has the same problem post so i can get the full story lol
Old Aug 28, 2009 | 10:27 PM
davo247d's Avatar
my bad i meant stock valve train
malteserunner's Avatar
Did you insert the jumper wire?
Old Aug 28, 2009 | 10:35 PM
davo247d's Avatar
ya i did but it seem like it did do anything
Old Aug 28, 2009 | 10:44 PM
Your CEL should flash if it's connected correctly. Here's some help.
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Aug 28, 2009 | 11:05 PM
2DoorRunner's Avatar
I would just get the valves adjusted while your in there, or a mechanic if you are taking it in.
My somewhat related question is: Is the timing chain tensioner operated by oil pressure? I was looking at a pic of a rebuild kit and thats what part of it seemed to be.
Old Aug 28, 2009 | 11:11 PM
Thats a cool page. The fuel pump test reminds me of winter time with my dad. When going up to our cabin our suburbans fuel pump doesnt work very well, so we just have the special paper clip to rig it to be always on.
Old Aug 28, 2009 | 11:21 PM
davo247d's Avatar
lol thanks for the help ill have to try those thing tommarow haha ive got a dead line cuz my dad is coming into town and i want the truck running top notch lol and ill get back to you guys on it but im still open to sugestions
Old Aug 29, 2009 | 04:56 PM
davo247d's Avatar
im pretty sure the engine is leaking anti-freeze into the oil idk for sure to
Old Aug 29, 2009 | 09:53 PM
Jay351's Avatar
Did you just replace the broken guide?
Or did you replace the timing chain and sprockets? If you didn't was the chain loose? Did it wear a hole in the timing cover?
Old Aug 29, 2009 | 10:35 PM
olharleyman's Avatar
did you verify TDC ? #1 piston at top , rotor pointing to #1 on the cap , timing mark on top just a bit before 12 o'clock , First two rocker arms have a little wiggle room , bottom at 6 o'clock(ya I know hard to do with the front of the motor together) and correct link in line with mark on gears? I had to recheck mine and had the same symptoms and found the distributor to be off one tooth , when every thing was lined up correctly (distributor gear can move as you install it on the timing gear that's what happened in my case ) timing was at zero on the guide and the timing gun. I run mine at 8* on the gun and it works great now that I have the 268 ENGNBLDR cam.
No you do not need to replace the stock valve train to run the 268 just set the intake at 7 and the exhaust at 9 per his directions and you should be good to go , I just installed mine Thursday night corrected it Friday afternoon and it runs great now that I got the dist. set correctly.
E-Bay chip is a joke keep your money
268 reference below
Old Aug 30, 2009 | 06:07 AM
davo247d's Avatar
lol i thought i had every thing lined up i had it a tdc and there was no hole in the cover, the weird thing is the first time i went tot do the timing it was right where it needed to be i was just haveing a heck of a time with the distributor and i did replace the chain and sprockets as well
Old Aug 30, 2009 | 06:53 AM
yoterr's Avatar
did you pull the head to do the job? i just went through a ridiculous time doing all that without pulling the head, ended up messin up the head gasket anyway,
Old Aug 30, 2009 | 06:57 AM
davo247d's Avatar
i didnt pull the head lol and when i wento put it back together i had removed most of the oil pan bolts so i could put it directly up on the headgasket
Jun 1, 2021 01:51 PM
ItsJustD
Jul 7, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
