22R replacement carb
Old Sep 28, 2015 | 12:40 AM
AKHeathen's Avatar
forgot about the warm air diverter, which is run through the valve in the air cleaner on the vacuum lines. you have to have that plugged with the air cleaner off. when it's all warmed up to operating temp, adjust the mixture screw a little at a time, giving time to catch up (3-10sec) until it idles highest, then should be like 1/8th turn lean after that setting. the idle might become too high, so adjust till you get the mixture right, and idle low enough, then do the slight lean adjustment.
kazuya2416
Apr 5, 2024 02:17 AM
sandyota
Feb 4, 2021 11:16 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
87blyota
Jul 10, 2015 04:31 AM
