21mpg normal for 2wd 91 toy truck?
Old Oct 18, 2005 | 12:17 PM
91RN81's Avatar
hey guys i got a 91 std cab. 2wd toyota truck in excellent shape, only has 98k miles. I've been calculating the gas mileage lately and im coming up at 20.8 mpg. I drive 80% city 20% highway and drive pretty easy. This seems a little low. I have heard stories about these trucks getting more like 25 mpg in the city. Anyone got a truck like mine with better gas mileage? thanks..
Old Oct 18, 2005 | 01:53 PM
Glenn's Avatar
I got 27 regularly in my former regular cab 2wd with 22R engine and 4 speed.
Old Oct 18, 2005 | 03:30 PM
ironroad9c1's Avatar
changed your O2 sensor lately?
Old Oct 18, 2005 | 03:39 PM
jimbo74's Avatar
i have an 85 4x2, i get 17 mpg..... but my truck is slightly modified
Old Oct 19, 2005 | 09:33 AM
91RN81's Avatar
just checked the air pressure in the tires and they were all below 20 psi. Didn't even look low? Anyways could i gain 1-2 mpg raising to say 35psi?
Old Oct 19, 2005 | 11:40 AM
Glenn's Avatar
What does the owner's manual say for tire pressure?
Old Oct 19, 2005 | 12:58 PM
91RN81's Avatar
not sure what the manual says but i always go by what it says on the tires..
Old Oct 19, 2005 | 01:51 PM
Glenn's Avatar
Go by the manual, not what the sidewall states. The sidewall will give you a maximum pressure for the tire itself. The manual will recommend a pressure for the tire/vehicle combination that works best for the vehicle. You may also find tire pressure information on the driver's door jamb.
Old Oct 19, 2005 | 08:24 PM
kyle_22r's Avatar
21 is definitely low for all-around driving. then again, i know the older trucks were rated at like 23 city, 31 highway.
Old Oct 20, 2005 | 06:22 AM
91RN81's Avatar
would 19 psi tire air pressure cause a big loss, 2-3 mpg?
Old Oct 20, 2005 | 01:58 PM
Glenn's Avatar
Why not fill up your tires to 30 lbs and see what happens to your gas mileage? 19 is really low.
Old Oct 24, 2005 | 11:16 AM
91RN81's Avatar
after inflating the tires to 32lbs I can't believe the difference in mpg, i just calculated it and have gained an honest 4mpg increase over before!! I now get 26mpg with mixed city/hwy driving. Check those tire pressures!!
Old Nov 9, 2005 | 04:58 PM
tc's Avatar
tc
My '89 2WD 22R 4Speed (with unbelievably high gearing) got 20.00000000000 MPG EVERY TANK both before and after the lift. If you went 200 miles, it would take 10.000 gallons. It was truly amazing.
Old Nov 14, 2005 | 08:29 PM
calib7's Avatar
enough said
Old Nov 15, 2005 | 04:03 PM
Elton's Avatar
lol i got a amazing 22 mpg lets see thats 80% highway at 60ish 2900rmps and 10% freeway at 75ish 3300rpms and 10% city of course i have some mods done
matrad
Aug 26, 2024 08:21 AM
DanStew
Jun 29, 2015 10:46 AM
MudDr
Jun 18, 2015 04:26 PM
dlotoy4runner
7
Jul 3, 2002 03:42 AM
