2 pinion or 4 pinion differential
code should either be on the door jamb or on the plate under the hood. for the most part(not necessarily 100%) if you have a 4 cylinder engine without the turbo, you'll have a 2 pinion rear. if you have a V6 or turbo 4 cylinder, most likely a 4 pinion rear, though i've seen some with 2 pinion.
pinion
OK I have a 94 v-6 auto and my vin # has a 2 in it and thats it so I was thinking of a 2 pinion and now I counted the ribs and now i'm thinking it's a 4. Now what. Thanks alot for the help and keep it coming. Sooner or later we'll get this figured out.
Thanks again, Dale
Thanks again, Dale
its most likely a 4 pinion...check here: http://www.4x4wire.com/toyota/faq/vin/
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Odin
Sep 26, 2015 06:56 PM
