1uzfe flywheel
Old May 20, 2009 | 04:27 PM
fmartin17's Avatar
1uzfe flywheel
looking for a flywheel here in the states for my 1uz swap. any body know how to get a hold of superrunner? went to his site and tried to email him but the link was broken. looks like i might have to break down and put some food on the aussies tables.
Old May 20, 2009 | 05:09 PM
RMA's Avatar
RMA
according to Lextreme a slightly modified 3sgte flywheel will work.
Here is the link ,towards the bottom.
http://www.lextreme.com/1uzfe_info.html
Old May 20, 2009 | 07:25 PM
DeathCougar's Avatar
Manual trans, or automatic? I don't believe a manual trans has ever been used behind a 1UZ in anything toyota brought to the US.
Old May 20, 2009 | 07:41 PM
T-1000's Avatar
There never was.
A 3SGTE flywheel is supposed to work in an A340E bellhousing though, when joined to an R series trans.
Old May 20, 2009 | 07:44 PM
RMA's Avatar
RMA
Cougar you can add to the world on the above not just US.
Toyota never mated the 1uzfe to a manual anywhere in the world.
Old May 20, 2009 | 09:20 PM
Jay351's Avatar
And thats why having one with a 5sp in a 4x4 is so damn awsume!!
Old May 21, 2009 | 05:53 AM
motoriderbc's Avatar
I have a 3SGTE ( 2nd gen MR2 turbo)flywheel behind my 1UZFE. They both have the same number of mounting holes, but the 1UZFE uses a larger radius. I had a machinist plug the original crank mounting holes and then redrill the 1UZFE pattern. The only other mod needed is to file a chamfer on the ring gear teeth since the 1UZFE starter is mounted on the engine side compared to the trans side on th 3SGTE. The 3.0l clutch bolts on with no mods.
Old May 21, 2009 | 07:49 AM
RMA's Avatar
RMA
You wouldnt have any pictures of the said flywheel and the modifications you did to it , would you .
Old May 21, 2009 | 02:12 PM
Jay351's Avatar
I demand pictures!!! So whats that bad boy in?
Old May 21, 2009 | 09:16 PM
Only pic I have of the flywheel is after the clutch was installed.
Using the stock R151 trans with an adapter plate:
It was installed in this(old pre-swap pic):
Old May 23, 2009 | 07:02 PM
Jay351's Avatar
Thats killer! Where the heck did you find an adapter plate around here? I really want to do this swap, but I have had a heck of a time finding anything locally.
Motor seems to run about 2k...
Old May 24, 2009 | 12:00 AM
I made the adapter plate out of 3/8" steel. Been working great so far. I picked my motor up off CL for $500 without ECM etc.
If anyone is interested maybe I'll do a build thread since there seems to be very few completed 1UZFE swaps in pick ups/4runners that are LHD and IFS.
Old May 24, 2009 | 10:46 AM
Jay351's Avatar
I would be extremly interested! I have yet to find a complete v6/1uzfe IFS r150f swap. And in my neck of the woods at that!!
So with the adapter plate, did you have to extend your transmission input shaft?
Sorry for the thread jack!!!
Old May 25, 2009 | 01:10 PM
fmartin17's Avatar
thanks for the info brothas, gonna get started on this b#tch this week. got everything i need.
Old May 25, 2009 | 03:41 PM
TNRabbit's Avatar
The R150F has a 160 mm input shaft (longer), so the extension on the adapter was to line it up with the 1uz crank. Not sure the difference between the R151F and the R150F??
1uzRunner
63
Nov 10, 2018 03:58 PM
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
sonorn67
Sep 19, 2015 05:39 PM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
