1st Toyota, 1st Post, 1st question
Old Mar 31, 2016 | 04:05 PM
lochenjons's Avatar
Today I bought my first toyota! I've always been a chevy man, but I wanted something cheap and fun to get me back and forth to work without putting a ton of miles on my lifted duramax... so I bought a 1989 Toyota for $750 (talked the guy down from 1300). 22R motor, 2 wheel drive, 5 speed, 290k miles. The truck runs great just as I would expect it to. Transmission seems strong. The only issues that this truck has are cosmetic. I have a hook up at the local junkyard so I am wondering what body parts will fit this truck? I need two front fenders, front bumper, and a bed/tailgate. Cause it's pretty thrashed. Aside from being my DD to work and back I want to fix it up and make it look nice-ish. But I would like to know what years/models will fit this truck when I go to the junkyard to look for parts. Thanks!
Old Mar 31, 2016 | 05:48 PM
slacker's Avatar
you need 2WD parts only ... unless you want to "modify"
89-95 typically are the same , other them maybe cosmetic or electrical plug ends
Old Mar 31, 2016 | 06:21 PM
lochenjons's Avatar
So all body panels have to be from a 2X4 no exceptions ?
Old Mar 31, 2016 | 07:01 PM
Havokgs's Avatar
Rock Auto seems to have the fenders you need, and there are different part numbers for 2wd and 4wd so panels are probably model specific, but not sure why.
http://www.rockauto.com/en/catalog/t...dy,fender,1380
Old Mar 31, 2016 | 07:44 PM
tj884Rdlx's Avatar
The fender panels are different with larger flares for tires to clear on a 4wd, but almost all parts can be made to fit if you are willing to "customize". I've seen bumpers, fenders, and grilles on the "wrong model".
That said, check carparts.com for cheap new parts, or car-part.com for a salvage yard database of used parts. Then there's always people parting out on Craigslist.
Good luck with your truck. Looks like a good deal.
Old Apr 1, 2016 | 02:55 AM
Terrys87's Avatar
On the 2wd trucks, some Ford rims will fit. Otherwise 89-95 2wd parts is about the only thing that will interchange. If you use 4wd fenders, then you would at least need to change the blinkers lenses as well.
Mini truckers use 89-95 4runner front ends on them but then you have to change fenders, grill, bumper, and blinkers is some of the things that I know of.
Old Apr 1, 2016 | 02:07 PM
lochenjons's Avatar
got it. thanks for the help. went to the pick n pull today... they only had one that fit my criteria and it was stripped bare! no one seems to like junking toyotas! looks like I'll be turning to craigslist and the websites mentioned above.
Old Apr 1, 2016 | 08:16 PM
85TurboRunner's Avatar
No, all body parts 2wd or 4wd fit the same. The 4wd fenders are wider but still bolt on the same way. The 2wd and 4wd beds are the same.
Its common to swap 4wd fenders onto a 2wd truck to give it a wider look.
Bumpers etc. are all the same.
Grills and marker lights changed through the years though.
Old Apr 1, 2016 | 11:02 PM
tj884Rdlx's Avatar
Don't know where you are but many good Toyota part-out ads on Atlanta Craigslist including a truck pictured looked just like yours. Good luck
Old Apr 6, 2016 | 08:30 AM
Jrheingans's Avatar
I'm parting out a 2wd 1984 right now and have fenders and a front bumper. Shoot me a pm if your still looking for these parts.
Old Apr 6, 2016 | 09:37 AM
Nervo19's Avatar
^^'89 and '84 pickups are different generations. '89 and '84 4Runners are the same is where the confusion sets in.
Old Apr 6, 2016 | 02:27 PM
GorgeRunner's Avatar
I get new aftermarket fenders on eBay pretty cheap. They don't "fit like a glove", but close enough to look good from the police helicopters.
Old Apr 6, 2016 | 02:29 PM
Meljo's Avatar
Ok so I'm new to this site and I don't know how to post a question. So I have a 94 toyota pickup with 4in suspension lift and want to know what's the biggest tire i can get on it? Thanks!
Old Apr 6, 2016 | 02:33 PM
Meljo's Avatar
Thx you guys are awesome
Old Apr 7, 2016 | 09:19 AM
Nervo19's Avatar
It's a little hard to find but there's actually a sub forum for tires. This thread should help:
https://www.yotatech.com/forums/f177...thread-169234/
You will run into gear torque and gas mileage differences with big tires so you have to research what seems right to you.
lbhsbz
Apr 2, 2018 01:13 AM
leojones251
Oct 15, 2016 04:30 PM
JCBond
27
Feb 8, 2016 05:00 AM
tjunit
Jan 20, 2016 07:43 PM
