1st gen shackle and spring bushings...options
Old Apr 23, 2007 | 07:00 PM
thook's Avatar
Hello all,
I've been searching for poly bushings for the '86 and found plenty...Daystar, Energy Suspension, etc. But, I haven't found anyone with greasable bolts and poly bushings....unless I just missed it.
Does anyone know where to get these at a good price? Are they made for this vintage?
Old Apr 23, 2007 | 08:52 PM
thook's Avatar
Bump..
Any you guys/gals that are around have any tips?
Old Apr 23, 2007 | 09:52 PM
pennywize's Avatar
check here, they have complete shackles and separate parts, greasable bolts and bushings. -----> http://trail-gear.com/shackles.html
Old Apr 23, 2007 | 09:57 PM
thook's Avatar
Perfect. Thank you.
Old May 3, 2007 | 06:59 AM
thook's Avatar
I've not ordered any bushings and shackle bolts, yet. I've searched, but I'm having trouble determining the length of bolts to order. Is the measurement to be taken from the whole length of the bolt or just the smooth part of the bolt shaft minus the threads?
Old May 3, 2007 | 07:34 AM
ewong's Avatar
bolt length is typicall the whole lenght of the bolt minus the hex head part...
The area w/o the threads is called the shoulder and thats spe'cd as a seperate measuerement on some bolts...
Old May 3, 2007 | 07:36 AM
MMA_Alex's Avatar
Wab Fab sells greasable ones, and marlin sells very similar non greasable ones
Old May 3, 2007 | 12:42 PM
thook's Avatar
Thanks to both of you.
Hmmm...WabFab page is almost identical to Trail Gear's page. Are they affiliated?
Anyway, it shows spacers available. What are those for? I've never done a shackle/spring bushing replacement before.
Old May 3, 2007 | 01:01 PM
MMA_Alex's Avatar
There are two types of shackles on these trucks. Straight, and offset. The difference is that on the straight the shackle hanger, and the spring are the same width. On the offset they're different widths, hence the spacers. I forget which uses which aside from the fact that 89-95 p/u's use the offset type.
Old May 3, 2007 | 03:18 PM
waskillywabbit's Avatar
I sell TG stuff and a lot more.
Old May 4, 2007 | 12:22 AM
thook's Avatar
Oh! Okay...that explains it.
And thanks, again, Alex.
Turns out if I still want fender flares to doll up the rusting body of my '86 I will have to forego greasable bolts. Which is fine, but I liked the idea of keeping them quiet and making the bushings last that much longer. Maybe later I can get some and put them in.
I'm still getting the poly bushings, though. Everything I read says they last much longer than OEM or stock replacements. Anyone here to agree? Even without grease points?
Old May 4, 2007 | 05:12 AM
MMA_Alex's Avatar
I've got the non greasable poly's, and so far I haven't had any issues (10k miles or so). If i do end up having to replace them they're cheap enough that the biggest concern would be making sure the bolts dont get rusted in place.
Old May 4, 2007 | 05:29 AM
amgraham's Avatar
Yeah, I have the Energy Suspension bushings... They've been on for about 11K miles and some hard wheeling and they are holding up great. I like how the poly bushings don't use the metal tube in the middle because that was seized on all my stock bushing bolts. Also, like was said, they are cheap to replace if need be. I think it was like $25 for the set.
Flying91
45
Apr 11, 2024 04:39 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Shagool22
Aug 14, 2015 12:24 AM
vanion2
Jul 29, 2015 06:17 PM
noahstancik
Jul 17, 2015 05:38 PM
