1st Gen 4runner rear 3 pt seat belts
Old Jul 3, 2017 | 04:46 PM
  #41
ewong's Avatar
Originally Posted by destrux
FWIW the factory option rear belts have the retractors in the same place the lap belts do.
Sort of
There were several models of 4Runner seats options
Mainly because - in the early years, rear seats were often a "port option" (it had to do with import tariffs)
So there were these "bench rear seat"t things out there
And some put the belt retractor on the roll bar
And some had "a static adjustable" shoulder belt and lap retractors (what I have added) with a detachable clip...
I'd be wary about using along bolt and flipping the retractor. Mainly because of leverage arm on the bolt.
But thats just me
Old Jul 3, 2017 | 07:11 PM
  #42
destrux's Avatar
Originally Posted by ewong
Sort of
But thats just me
I'm referring specifically to the belts Toyota lists currently as replacement parts for $114 each. They mount with original hardware as intend, no flipping anything around.
Although I think some searching in the yard through other cars might find identical belts in some other Toyota model.
Old Jan 23, 2021 | 08:56 PM
  #43
Partyof6's Avatar
Build thread
Originally Posted by stanz
See my build thread
Not sure how to navigate this site yet.
So. If you even see this. Is the build thread still available?
Thank you
Old Jan 23, 2021 | 10:38 PM
  #44
SomedayJ's Avatar
Thank you
He has a link to his build thread in his signature.
You have it here also:
https://www.yotatech.com/forums/f199...runner-252537/
Old Oct 3, 2021 | 03:37 PM
  #45
SWitek's Avatar
Originally Posted by crashburnoveride
Ok I put 2 washers on there and it enables you to run it normal. Only spent $20 at the junkyard.
Attachment 111864
How does adding washers undo the twist? Wouldn't the belt need to flip? I just some front belts out of a 2nd gen and they are flipped like in this pic. I would rather they flow smooth. Do I just need to flip the belt? (But then the bolt bracket on the other end would be flipped and can't install). Help!
Old Oct 3, 2021 | 04:14 PM
  #46
crashburnoveride's Avatar
This was ages ago, but I think the washers space it out enough so you can flip it so the belt guide part doesn't contact the roll bar.
I8URSVT
Oct 23, 2016 04:33 PM
Lotus1
Jul 31, 2008 11:38 AM
ads86runner
Aug 30, 2006 01:39 PM
