1st gen 4Runner (89) brake upgrade question
Old Nov 4, 2014 | 05:32 AM
clok's Avatar
i am trying to piece together all the parts i need to upgrade my 89 1st gen. brakes , i have done the search and research on here and know what parts i need , but when i picked up my master cylinder for a 95 v6 4x4 4runner i got one for a 4 wheel abs disk , is there gonna be any problems hooking this mc up does it matter that its a for 4wheel disk with abs i dont have abs and the master cylinder only has two ports and the reservoir and the plug for the warning light and the ports are even positioned the way the ports are positioned on the the original mc, so need to bend the brake lines to line up with mc, it is thou the 1 1/16 bore mc but gonna run the 96 t100 brake booster and 95 4runner calipers so not worried about the 1 1/16 bore size , iknow everyone is using the 1" bore but heard the 1 1/16 will work fine. ok please tell me i should be fine using the 95 4runner mc with 4 wheel abs thanks.
Old Nov 4, 2014 | 08:11 AM
RustBucket's Avatar
If it only has 2 ports then you are probably OK. The difference between ABS and non-ABS may just be the size, maybe compensating for having to push more fluid into the ABS system. Just guessing.
Try it and see.
Old Nov 7, 2014 | 04:43 AM
BigBluePile's Avatar
Sure.
Old Nov 7, 2014 | 05:01 AM
Rowdydudeman's Avatar
11/16" or 1 (and) 1/16"...? lol
Old Nov 7, 2014 | 05:20 AM
lol, indeed.
Old Nov 8, 2014 | 03:38 PM
clok's Avatar
http://flic.kr/p/pZbqAc
Almost ready for brake upgrade , just need the rotors now!!
Old Nov 9, 2014 | 10:00 PM
clok's Avatar
http://flic.kr/p/q1bJHt Painted the calipers today with duplicolor caliper paint kit , came out super nice , this wAs after two coats brushed on , looks new ! , think I'll do one more coat for kicks , the paint has ceramic in it so can handle high heat and according to some reviews I read lasts for years without fading or peeling off.
http://flic.kr/p/p4st8B
Old Nov 10, 2014 | 12:13 AM
wyoming9's Avatar
Red face
I for sure would not want the nightmare of replacing your brake parts if something fails.
You did go with new parts??
Old Nov 10, 2014 | 07:42 AM
RAD4Runner's Avatar
Thanks for posting, Clok!
Would you mind posting pics of mechanism between brake pedal and the booster or the master cylinder? I feel intermittent binding on mine.
TIA
Old Nov 10, 2014 | 11:11 AM
clok's Avatar
Originally Posted by wyoming9
I for sure would not want the nightmare of replacing your brake parts if something fails. You did go with new parts??
New master , new brake booster , new rotors, got new hawk front pads , used 1995 4 runner calipers , why would it be a nightmare to replace my brake parts , I just buy pads for a 95 runner ? Or mc from 95 runner , or booster from 95 t100 , pretty simple , but I got all new oem parts at that.
Old Nov 10, 2014 | 11:17 AM
clok's Avatar
Thanks for posting, Clok! Would you mind posting pics of mechanism between brake pedal and the booster or the master cylinder? I feel intermittent binding on mine. TIA
http://flic.kr/p/p4QaeN Here's a pic. Of the back of the brake booster
http://flic.kr/p/pYwe77
And a pic of the back of master cylinder
Let me know if this helps you out , won't be installing it till next week thou.
Old Nov 12, 2014 | 04:48 PM
RAD4Runner's Avatar
[url]Here's a pic....
Greatly appreciate it, Sir!
The threaded rod is the one that is linked to the brake pedal through the firewall, correct?
and there's really not much I can inspect for binding unless I un-mount the booster from firewall, correct?
Except, that I can disconnect the rod from brake pedal and inspect the pedal and bracket alone?
Is it pretty straight forward to remove master cylinder and brake booster from firewall?
Thanks again!
Old Dec 15, 2014 | 01:30 PM
clok's Avatar
Brake upgrade is done , new mc , brake booster , calipers , rotors, pads and switched to freshly rebuilt manual hubs.
http://flic.kr/p/qqrNbH
http://flic.kr/p/ptCvsU
http://flic.kr/p/q947nw
http://flic.kr/p/q9cMzx
Braking power has improved !!!
Old Dec 15, 2014 | 04:35 PM
RustBucket's Avatar
Nice work! Good to hear that it helped. What's the casting number on the calipers? S12W?
Old Dec 15, 2014 | 05:08 PM
clok's Avatar
Calipers are s13 from a 95 4Runner.
AustinTaco
Aug 22, 2022 10:45 AM
TNRunner88
Jul 1, 2015 08:00 PM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
