1994 T-100 Vehicle speed sensor?
Old Feb 11, 2015 | 08:40 AM
HTi's Avatar
HTi
1994 T-100 3.0L 4wd. I have an MIL (code #51 I believe for the vehicle speed sensor) that comes on at highway speeds. speedometer doesn't work, as well as odometer(at all times).
I'm curious if there are any common problems with this? And what are the possible fixes? Thanks.
Old Feb 11, 2015 | 09:09 AM
scope103's Avatar
VSS1 (electronic sender to the combo meter and others) is probably bad (though, of course, it could just be a wiring issue). They usually degrade slowly; first with the occasional drop to zero MPH then pop up, until it gets longer and longer.
RockAuto has the part, but there are different ones based on your transmission, etc. RockAuto has pictures of each one, so it is reasonable to remove your existing one and match the picture.
The part is expensive, so if you're so inclined you should test it first. https://www.yotatech.com/forums/f116...n-done-286682/
Old Feb 11, 2015 | 09:12 AM
Odin's Avatar
I have a 91 that has a VSS fault too, I'm sure by 94 they're different.
I don't have an odometer and my speedo functions normal with no funny business.
Old Feb 11, 2015 | 09:19 AM
scope103's Avatar
If you have the cable speedo, VSS1 is a reed switch inside the combo meter. The diagnostic for that type can be found here: http://personal.utulsa.edu/~nathan-b.../6combinat.pdf (BE-33)
Old Feb 12, 2015 | 08:13 AM
HTi's Avatar
HTi
Thank you. Do you happen to have a write-up on replacing this part?
Old Feb 12, 2015 | 08:22 AM
scope103's Avatar
Originally Posted by HTi
... Do you happen to have a write-up on replacing this part?
Uh, no.
Let's see. "Remove connector. Remove hold-down bolt. Pull sensor straight out."
The replacement sensor won't have the drive gear, but it's pretty obvious how to swap in the old one.
Old Feb 20, 2015 | 04:35 PM
HTi's Avatar
HTi
I can't seem to locate the part on RockAuto. Do you have a link? I believe I have the cable speedo, so the VSS is in the instrument cluster?
Old Feb 20, 2015 | 05:20 PM
scope103's Avatar
Look under "Electrical" "Speed Sensor."
My '94 has the electronic VSS1, so I would be surprised if you have the cable. (But there is a part number for one http://www.toyotapartsoverstock.com/...371034010.html, so wadda I know?) But the cable is pretty big; you should see it sticking out of the transfer case in the place the drawing shows VSS1.
IF you have the cable speedo, you can lose VSS1 and the speedometer can still work. Since you've lost the speedo and odometer, if you have the cable I would suspect THAT is what is bad.
Old Feb 21, 2015 | 10:41 AM
HTi's Avatar
HTi
Okay I confirmed the cable for the speedo. I pulled the cable out from behind the instrument cluster and its clearly broken. It would make sense that the cable broke: The speedo quit and MIL came on suddenly as I was driving.
Sorry for all the trouble, you have been very helpful.
Flying91
45
Apr 11, 2024 04:39 PM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
coffey50
Jul 28, 2015 10:55 AM
wilbertd
Jul 6, 2015 07:39 AM
