1994 4runner Power problem
Old Oct 1, 2017 | 02:27 PM
87and94's Avatar
Okay I turned in the Optima battery at AutoZone and got a brand new one hooked it all up and still no power going anywhere
Old Oct 1, 2017 | 05:38 PM
akwheeler's Avatar
do you have a volt meter?
Old Oct 1, 2017 | 06:04 PM
87and94's Avatar
It's acting really really weird had full power but it wouldn't even attempt to turn over when I would turn to start it would be like turning it off a friend of mine said that it would be the starter or the positive wire going from the battery to the starter because later on that day I hooked up the Brad new battery and very little power would be going threw
Old Oct 1, 2017 | 06:15 PM
RAD4Runner's Avatar
Where are the periods?
Originally Posted by 87and94
1994 4runner no power going anywhere for it do alittle power will go threw but not enough to let it turn over
How do you know power is not getting anywhere? Troubleshooting for two days without a multi-meter is a waste of time. Two days costs more than the $7 you could have spent at Harbor Freight for a multi-meter.
Make a simple list of what work and what do not work. Not wordy, just a simple list.
Old Oct 1, 2017 | 06:18 PM
  #25
87and94's Avatar
I have one I just have no idea how to use it and it's probably broken
Old Oct 1, 2017 | 07:01 PM
  #26
scope103's Avatar
Then you're in luck! https://www.harborfreight.com/7-func...ter-90899.html
Use the $2.50 you just saved and buy a box of periods. Your postings are completely incomprehensible. If you don't know how to use a multimeter, you have to learn how. Posting here will only get people like RAD4Runner to give you voltages and continuities to look for; he's not going to hold your hand.
Old Oct 1, 2017 | 07:17 PM
  #27
87and94's Avatar
Okay ill go get one after school and keep you posted.
Old Oct 1, 2017 | 07:37 PM
  #28
RAD4Runner's Avatar
Cable ends have been cleaned many many many times when hooked up to jumper cables very little power tracked threw anything it's like a flashlight where the battery is about to die where it's just not enough to power and that was with the street that's in and the battery out of my 87
You cleaned the cable ends. Which ends? How about ALL connections from your battery to fuse block, to body ground, to block ground, to starter solenoid positive, including battery posts?
How clean is clean? In my book, clean is bare, shiny metal tightly touching bare, shiny metal.
Originally Posted by scope103
...Use the $2.50 you just saved and buy a box of periods..
LOL!
Old Oct 2, 2017 | 05:59 AM
  #29
87and94's Avatar
I have a new 80A fuse I need to out in but I can't open up the fuse box. Not the lid the actual fuse box so I can unbolt the old 80A and put this one in.
Old Oct 2, 2017 | 07:49 AM
  #30
akwheeler's Avatar
I have never seen a fuse that couldn't be replaced without disassembling the fuse box. they either pull out or are screwed down with easily accessible screws. Maybe you should post some pictures, and while you're at it, did you blow the fuse during your troubleshooting or did you find that this was your problem all along? Did you get a meter? There are people on this site that can teach you a lot, but if you don't have a meter or are unwilling to learn how to use it there is no way to help you with electrical diagnostics.
Old Oct 2, 2017 | 07:56 AM
  #31
scope103's Avatar
I've never done it, but this write-up seems pretty clear to me:
https://www.yotatech.com/forums/f116...cement-228307/
Old Oct 2, 2017 | 07:59 AM
  #32
akwheeler's Avatar
Ah, yes I forgot about the fusible link!
Old Oct 2, 2017 | 07:56 PM
  #33
87and94's Avatar
Okay here is where I stand I have a yota buddy he's pretty sure that it's the positive running to the starter that's messed up but another friend of mine was looking at it, he works at AutoZone and I know that doesn't make him a mechanic haha. But he thinks it's the voltage regulator.
Old Oct 2, 2017 | 09:18 PM
  #34
RAD4Runner's Avatar
...a yota buddy he's pretty sure...
...he thinks it's the voltage regulator.
Your autozone friend who thinks it's the regulator is definitely NOT a mech.
Your yota buddy is "pretty sure"
.. Now you need to be positively, absolutely sure. How do you do that? By using your multi-meter and your senses of sight and touch. Metal looks shiny? Feels smooth and clean? Connections feel tight? See the electrons running to one spot? Do they keep on going, or do they stop? OOPS, sorry... you're gonna need the multi-meter to "watch" the electrons run.
Old Oct 2, 2017 | 09:33 PM
  #35
RAD4Runner's Avatar
The 87 is my daily I drive it everyday I k ow the battery is fine
How do you know the battery is fine?
When you turn on the headlights, do you see how fast the electrons ran?
If you saw them run but stop somewhere, that somewhere is your problem.
I have a new 80A fuse.
Why did you get a new 80-amp fuse?
What makes you think replacing the 80-amp fuse will fix your problem?
How did you know it's bad? Did you see the electrons run then stop at the 80-amp fuse as if it were a collapsed bridge?
How much did the new 80-amp cost compared to a multimeter?
I'm trying to stress afew points here. "Pretty sure" or "thinks" troubleshooting will result in "pretty expensive fix that may or may not solve your problem"
​If you don't have a multi-meter or are not willing to learn, then it's not your business to troubleshoot an electrical problem. Take it to a competent and honest electrician/mech.
Old Nov 11, 2017 | 05:42 PM
  #36
87and94's Avatar
She's fixed!!
All right y'all it's been awhile since I posted about the 4runner today i changed out the positive terminal connected it to the battery turned the key and it fired right up no problem that k you all for the help!!
Old Nov 11, 2017 | 07:32 PM
  #37
akwheeler's Avatar
that would have been a lot easier if you got a voltmeter and worked through the system like everyone was trying to get you to do.
Old Nov 11, 2017 | 08:13 PM
  #38
87and94's Avatar
It's not that I didn't try that I was using a multimeter except I found out later that it was a broken one
