1991 Sr5 intermittent engine issues.
I have had this truck for 3 years now, and it has done this since the day I bought it. BUT it always eventually clears up, and once it is warmed it runs perfectly.
So I start it, it always fires right up, it will run fine for about 5 minutes at idle, then start missing like crazy, smells very rich, smokes, and usually dies unless I work the throttle like mad to keep it going. Then a few minutes later it clears up and is fine. The engine light does come on, but the local guys couldnt get their scanner to read it. Wasted $70 there. They said it had low compression, 60 lbs. (has 180K so Id say thats normal )?
Once its warmed up, it doesnt have a problem, usually. It does occasionally do this once warm however, rarely.
I use this rig for hunting and ice fishing, so I dont drive it a ton, but I want to figure out what the heck is going on.
IMO, when the temp gauge finally is at about mid point, it is gonna be fine. I am wondering if there is a temp sensor on these that may be faulty? I does seem to run better (not misfire) as much in the winter. Could be wrong , but it seems that way.
Where the heck would you guys start ?
Thanks, stumped in Minnesota...
Where did you go that doesn't know how toyota codes are read? Just paperclip between E1-TE1, turn key on, (don't start), and watch the light blink out a code. here's how.
http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Enjoy!!
Edit: sounds like a CSI or CTS issue. Cold Start Injector, Coolant Temp Sensor. But get the code, and troubleshoot. Don't waste time at SteveBob's autoparts getting fleeced for your cash.
Enjoy!!
https://www.youtube.com/watch?v=FoS2...ature=youtu.be
I took a video, Im seeing 3 different codes correct ?
Just glanced over post, when I first read it, missed some things. I would ask for my $70.00 back as you paid for them to say they don't know how to repair vehicles.
Compression should be 155 - 170
Minimum 142
14 psi variation between cylinders
This may help:
Minimum 142
This may help:
Ok after looking at it a few times I see a 22 code, then a 43 code, correct. I understand the 22 code, Ill check the wiring and sensor, but the 43 code if I am reading it correctly, is confusing. STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM,...
I wouldn't even trust there findings. I bet they didn't have WOT when doing it. My suggestion is to re-do compression test. As for codes if you have a Factory Service Manual it will guide you diagnosing codes.
Try looking here, its the shortest, clearest, code 43 tech I could find. The code 22, I would check the temp sensor wiring, plug, and at least remove, clean, and test the coolant temp sensor. Apparently 43 isn't horrible, but is a fixable issue.
Sent from my LG-P505 using YotaTech
It could have. Lemme play with it.
Edit: works on my phone browser, use the 90-95 4runner, or 93 truck 22re/3vze FSM. Lemme try to link.
http://web.archive.org/web/200807300...993/index.html
