1991 Sr5 intermittent engine issues.
Old 12-15-2012, 07:48 PM
Bojack's Avatar
I have had this truck for 3 years now, and it has done this since the day I bought it. BUT it always eventually clears up, and once it is warmed it runs perfectly.
So I start it, it always fires right up, it will run fine for about 5 minutes at idle, then start missing like crazy, smells very rich, smokes, and usually dies unless I work the throttle like mad to keep it going. Then a few minutes later it clears up and is fine. The engine light does come on, but the local guys couldnt get their scanner to read it. Wasted $70 there. They said it had low compression, 60 lbs. (has 180K so Id say thats normal )?
Once its warmed up, it doesnt have a problem, usually. It does occasionally do this once warm however, rarely.
I use this rig for hunting and ice fishing, so I dont drive it a ton, but I want to figure out what the heck is going on.
IMO, when the temp gauge finally is at about mid point, it is gonna be fine. I am wondering if there is a temp sensor on these that may be faulty? I does seem to run better (not misfire) as much in the winter. Could be wrong , but it seems that way.
Where the heck would you guys start ?
Thanks, stumped in Minnesota...
Old 12-15-2012, 08:12 PM
Bojack's Avatar
I should add its a 4 cylinder ...
Old 12-15-2012, 09:07 PM
ksti's Avatar
Could be cold start injector
Old 12-15-2012, 09:39 PM
combatcarl's Avatar
Where did you go that doesn't know how toyota codes are read? Just paperclip between E1-TE1, turn key on, (don't start), and watch the light blink out a code. here's how.
http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Enjoy!!
Edit: sounds like a CSI or CTS issue. Cold Start Injector, Coolant Temp Sensor. But get the code, and troubleshoot. Don't waste time at SteveBob's autoparts getting fleeced for your cash.
Old 12-16-2012, 05:34 AM
Bojack's Avatar
Thanks Ill try that here in a few minutes, I took it to a shop here in Bagley, Mn. Guess I was fleeced. Thanks guys, I will let you know how it goes.
Old 12-16-2012, 05:35 AM
Bojack's Avatar
What is standard for compression on these engines by the way/
Old 12-16-2012, 07:25 AM
Bojack's Avatar
https://www.youtube.com/watch?v=FoS2...ature=youtu.be
I took a video, Im seeing 3 different codes correct ?
Old 12-16-2012, 07:47 AM
Bojack's Avatar
Am I getting 3 different codes here ? Looks like coolant sensor is a 22 code but not sure if I am reading this correctly ...
Old 12-16-2012, 08:30 AM
ksti's Avatar
Just glanced over post, when I first read it, missed some things. I would ask for my $70.00 back as you paid for them to say they don't know how to repair vehicles.
Compression should be 155 - 170
Minimum 142
14 psi variation between cylinders
This may help:
Bojack's Avatar
Ok after looking at it a few times I see a 22 code, then a 43 code, correct. I understand the 22 code, Ill check the wiring and sensor, but the 43 code if I am reading it correctly, is confusing. STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM,...
Old 12-16-2012, 08:33 AM
Bojack's Avatar
If this actually had 60 pounds compression would it even run? I mean it runs perfect when its not missing...
Old 12-16-2012, 11:14 AM
ksti's Avatar
There is a procedure doing a compression test. SteveBobs didn't even know how to pull codes, I wouldn't even trust there findings. I bet they didn't have WOT when doing it.
My suggestion is to re-do compression test. As for codes if you have a Factory Service Manual it will guide you diagnosing codes.
Old 12-16-2012, 05:31 PM
Bojack's Avatar
Totally agree. (what are the procedures for testing that, I do have a compression tester Ill do that tomorrow too ). Did that video work ? Thanks for the help.
Old 12-16-2012, 06:29 PM
ksti's Avatar
Sorry, I'am having trouble up loading FSM page for compression test. Hopefully someone else will read this and post it.
Old 12-16-2012, 06:42 PM
combatcarl's Avatar
Try looking here, its the shortest, clearest, code 43 tech I could find. The code 22, I would check the temp sensor wiring, plug, and at least remove, clean, and test the coolant temp sensor. Apparently 43 isn't horrible, but is a fixable issue.
Sent from my LG-P505 using YotaTech
Old 12-16-2012, 06:43 PM
combatcarl's Avatar
In my signature, baby! OP, just look thru the FSM, you'll find the procedure!
Old 12-16-2012, 08:23 PM
Bojack's Avatar
Thanks guys
Old 12-16-2012, 08:48 PM
Bojack's Avatar
Combat carl I cant get that link to work for the 91 r22, maybe the link changed ?
Old 12-16-2012, 10:40 PM
combatcarl's Avatar
It could have. Lemme play with it.
Edit: works on my phone browser, use the 90-95 4runner, or 93 truck 22re/3vze FSM. Lemme try to link.
http://web.archive.org/web/200807300...993/index.html
Old 12-16-2012, 11:08 PM
hiGis's Avatar
I really used to think that my truck was the only one in the world that did that!
you described exactly everything my truck does! the only thing is that mine is a 3vze!
what would you do if it is the CSI??
Quick Reply: 1991 Sr5 intermittent engine issues.
