1991 Sr5 intermittent engine issues.
#26
Just be sure to look at the 22RE (4 cylinder) section at the top and not the 3VZ-E section (6 cylinder). I've made that mistake before and was searching for a screw that didn't exist on my engine
#27
I checked the wires to the CTS, I didnt remove the plug but the wires looked fine. The local NAPA has it for $50
so before I buy it, is there any test I can do ? Is that sensor one that reads resistance ? I am an Hvac tech so I do know how to handle a multimeter. Thanks.
#28
https://www.yotatech.com/forums/f116...uences-216515/
Try in there, couple posts down.
Sent from my LG-P505 using YotaTech
#31
http://www.autozone.com/autozone/par...966186_0_18589_
Just be sure to double-check the grooves, this one is offset so make sure your connector is the same way.
#33
I did replace the sensor and I have not had any issues. However the old fix one thing, fix another came up. Replaced a rear ujoint, next day front wheel bearing locked up, fixed that today. Can anyone tell me where the rheastat is for the fan control, mine only works on high speed.
#34
I might be able to help on this one, maybe not (assuming you mean the fan control switch for the cab). From what I gather, there's two possible culprits. Mine went out and only had "OFF" and "HIGH" speeds that were working. It quit on me one day and smoke came out of the dash. If that's the case, your fan control speed switch short-circuited. I took mine out and was black and burnt. New one cost me $45, but the junkyard might be a cheaper solution. The second culprit is the fan resistor, located under the glove box on the passenger side. I have no experience with this, since it wasn't my issue but I know others around here have done it. If you start a new thread you'll get some replies.
#36
Here's a link to the Factory Service Manual (FSM) that explains the "blower motor". If you haven't already, bookmark it. It's the manual that Toyota mechanics use since it documents how to fix ANYTHING on the truck. Note that it's for a '93, but it's pretty close to any model between 89-93. Only main differences is the throttle body that I've found.
FSM Manual
FSM Manual
