1991 3.0 Head gasket Repair advice
#143
Thanks everyone for the replies, and thank you for the gasket pic! That will come in handy!
#144
So, Im in the middle of putting my passenger side cam back in place along with bearing caps and seals when I realize.. I dont believe I recieved a 'camshaft housing plug' aka the rear cap that seals the cam. Note picture below
That is a picture of my old one. Is this a part that I can reuse? Obviously I need to give it a good cleaning, but can I just use it again? I dont know if Dallas Toyota missed it, but maybe its just not included in the gasket kit which is odd since you have to pull the cams to get the head bolts out. Input?
Edit: And while we are on the topic of these things.. Do you use any RTV on the front or rear seals/caps?
#146
You are right about that. They are feeling pretty solid and I think I agree. It would be a good idea to get new ones. Last thing I want to do is put it all back together to find out these things leak..
#152
Ah damn! No I didnt. You think it will be an issue since the other 6 are fine now?
On another note, finally got back to working on it again, was torquing down the cam bearing cap bolts and 2 stripped. After doing some searching it looks like we are going to be running to the store to get a helicoil setup. Argh.
#153
maybe research what exactly the cold start injector does....i honestly have no clue except that it has to do with fuel....likewise, at least that part is easily accessible if there is an issue....unlike the injectors.
oh dear....about the helicoil.......ouch.
#154
I wouldn't worry about the CSI, it should only be a factor during start up. Mine went bad once and sprayed continuously which made the truck run crazy rich and it wouldn't idle. If that happens to you at some point, send it off the Witchhunter then.
#155
Thanks for the input. So Im kinda stuck with this whole helicoil thing. I drilled it out and am attempting to tap it but after about about 1/4 of an inch, the whole cylinder starts spinning. Its the little collar that sticks up from the bolt hole for the bearing cap. What do I do? I cant seem to get far enough to then screw in the helicoil.
#157
when I did that to mine, I took that sleeve out, the threads should be in the head. But it might be different on the 3.0. When I was done putting the helicoil in, I put the sleeve back in.
#158
Im going to have to give that a go! You just grip and rip to get them out? Anyone know for sure that this is okay to do on the 3.0?
#159
Little update!
So the power is back on (it was a little windy up here last night!) and with a better attitude and some hope (thanks again xxxtreme) we went out there and managed to pull the little sleeves out. The threads for the bolts that hold down the bearing caps are in fact in the head. Just FYI to anyone else looking to do this, the bolt is a M8-1.25 and the drill bit needed was a 21/64.
