1991 3.0 Head gasket Repair advice
Old Nov 16, 2010 | 10:43 AM
  #161
POTAzoa's Avatar
did you determine what caused the head gasket failure or just replacing everything it could be? is there any way to even tell what the problem was or just replace stuff?
Old Nov 16, 2010 | 12:34 PM
  #162
RedYota91's Avatar
Never really figured out what caused it although Im pretty sure it was the passenger side that went. All the pistons cleaned up easily (like they had been steam cleaned quite a bit..) whereas the other side had plenty of gunk.
Btw- This thing ended up taking 4 helicoils. 92 Toy- I'd prepare for it.
Old Nov 16, 2010 | 12:40 PM
  #163
xxxtreme22r's Avatar
hahah he's got my number already. lmao.
Old Nov 16, 2010 | 03:49 PM
  #164
RedYota91's Avatar
Ah crap. I dont remember where these brackets go.. :/ I know they attach to the valve covers somewhere..
Old Nov 16, 2010 | 07:21 PM
  #165
Sansocal's Avatar
brackets
those brackets go in between the heads and valve covers, facing outwards, to hold the wires. They used to have black plastic covers for the wire harness... mine broke, so i just zip tied the wires to the bracket.
Old Nov 16, 2010 | 07:24 PM
  #166
RedYota91's Avatar
Perfect! All my black plastic is gone too so looking at these and the wires I was like...'uhhhhhhh'
Old Nov 16, 2010 | 09:37 PM
  #167
RedYota91's Avatar
Ah fiddlesticks!
That one broke at probably 40 ft/lbs while trying to torque up to 122! We were moving along nicely tonight and this happened. After this step, and a few timing belt covers, we would've been putting the upper intake manifold on! Looks like I need to find a few more bolts!
Old Nov 17, 2010 | 12:45 AM
  #168
TNRabbit's Avatar
I just wrapped my harness in a sheet, then wrapped electrical tape around that & zip tied it to those rails~
Ah fiddlesticks!
WTF were you trying to torque it to 122?!?!?? No wonder you're breaking so many bolts!!
Old Nov 17, 2010 | 02:15 AM
  #169
Andy A's Avatar
I'll say, 122 ft/lbs ouch. The cam bearing caps are at 12ft/lbs and the lower intake bolts and 4 nuts at 13ft/lbs
Old Nov 17, 2010 | 06:55 AM
  #170
Wrenchinjoe's Avatar
Wasn't there a post last night about the plastic cups your fuel injectors sit in having different depths? Couldn't find it when I went back...?
The old seals got stuck in a couple of mine and it was hard to see. That made it appear they were different depths though. Once I got the old seals out, the injectors all seat to the same depth.
Old Nov 17, 2010 | 08:02 AM
  #171
RedYota91's Avatar
Thats EXACTLY what it was. After some prying with a screw driver and a 'doh', I figured it would be best to just delete the post.
And now, after looking at the online manual again, I dont know where we got 122 ft/lbs. When I made the post last night, my little brother was the one that twisted it off and told me the details, I just posted the pics. And after looking at the repair manual, I dont know why he thought 122...Must've just been delirious from working on this thing all day! Well, lesson learned. We were able to just twist it out and I'll run and get another one today.
Old Nov 17, 2010 | 09:01 AM
  #172
RedYota91's Avatar
WTF!?!?!?!
If you notice my original post about the 122 ft/lbs, I had edited it right after I had posted because my brother said it was 113 ft/lbs and then later said 122..
Well I called him today to flip him a healthy dose of crap because I made myself look like a no0b online and he said that, no, it said we needed to torque it up really high! After looking at the ncttora.com online repair manual, I told him no. Well, he pulled up the PDF file that I had downloaded from Toyota at the beginning of all of this and this is what it said...!
HA! WTF?!
Old Nov 17, 2010 | 09:02 AM
  #173
RedYota91's Avatar
And just for comparison, ncttora.com:
Old Nov 17, 2010 | 09:10 AM
  #174
RedYota91's Avatar
And HEY, jerk, (online joking only, not really trying to be rude..) the only other stripping issue/breaking bolts that we've done were the bearing caps on the cams.. We were hand tightening them and they just started free spinning. They NEVER got higher than the 12 ft/lbs that they required.
Old Nov 17, 2010 | 09:14 AM
  #175
looks like someone put an extra 1 in that 13.
Old Nov 17, 2010 | 09:15 AM
  #176
Old Nov 17, 2010 | 09:25 AM
  #177
RedYota91's Avatar
Exactly. I think Toyota should pay for the $2 bolt that I have to go buy..
Old Nov 17, 2010 | 10:19 AM
  #178
TNRabbit's Avatar
Not the first time I've been called a jerk.....I'm CERTAIN it won't be the last~
Old Nov 17, 2010 | 10:27 AM
  #179
92 TOY's Avatar
wow....that's quite the typo!! good thing it only resulted in that one broken bolt.
Old Nov 17, 2010 | 10:35 AM
  #180
RedYota91's Avatar
Im just glad that it was easily removed. Had it broken off down lower, I wouldve been a tad bit more frustrated.
