1990 4Runner Long Travel Suspension
Old May 6, 2007 | 01:26 PM
tclutts's Avatar
What manufactures produce the best Long Travel Suspension lift? I am looking for about a 4" lift from my 1990 4Runner. Any one got some pics and suggestions?
I am also needed a repair diagram to fix my sunroof.
Thanks
Old May 6, 2007 | 01:28 PM
UK Drew's Avatar
on the rear im running HDJ80 landcruiser springs and +4 pro comp ES 3000 shocks, no sway bars.
pops its wheels like a good un
Old May 6, 2007 | 01:40 PM
chimmike's Avatar
I think he means front end (where there is little to no travel) haha.
Old May 6, 2007 | 01:48 PM
UK Drew's Avatar
front end... that sucks
rear is plus 3 inches and front is plus 2 inches.
heres a side pic
getting long travel out of the front IFS is going to be a solid axle swap.
Old May 6, 2007 | 01:52 PM
ewong's Avatar
LT is $$$ if yer just looking for "lift" there are cheaper ways to do it.
Also - I would NOT be surprised if a SAS is CHEAPER than IFS LT.
That being said - Im planning a IF SLT for my 89 (gen1) 4Runner.
You'll need
-- LT kit
-- T100 axles
-- fiberglass fenders
-- BFH to do the body seam mod to fit 33"s
Out back - Im not as familiar with the LT options as I have leafs out back.
Alot of prerunners tend to convert to leafs out back.
Biggest issue is runing LT shocks in the back w/o cutting holes in the back or a 4Runner.
Cantelever and Mezzanine are the two types of rear suspension that I've seen that can let you keep the rear cabin and run true LT (13"+).
There are a few LT front setups
-- Downey 2" wider (not a fan myself, but its out there)
-- Total Chaos 3.5" wider (biggie seller)
-- former ATS - now out of a Toyota shop - Inland Toyota?
-- custom
Dunno off the cuff who else has a bolt up for the 85-95 erar IFS.
The rear is an issue becuase the OEM control links length is very short for LT. So the issue is runing new longer links... basically turns the deal into a custom job. Gas tank gets in the way too...
Search on TTOR under the Long Travel Suspenion forum.
There's someone making wider glass for the rear of the Gne2 4Runner...
Old May 6, 2007 | 01:55 PM
ewong's Avatar
No
- SAS
- about 2-3x that in $$ for LT IFS...
check out the total chaos fabrication site
Mind you LT is for "dez running" not rock crawling...
To do it right requires $$$ in shocks. Ya figure a 2.5" coil per side, a triple bypass per side and a jounce shock per side... thats like $4500 in SHOCKS alone not counting the kit (off the cuff prices)
Old May 6, 2007 | 01:58 PM
UK Drew's Avatar
we sure dont do as much extreme fabrication as you guys. off the top of my head i can only think of one person who has done the SAS
Old May 6, 2007 | 02:05 PM
ewong's Avatar
you want toyota fabrication?
surf over to www.pirate4x4.com.....
Old May 7, 2007 | 02:37 PM
91ToyTrck's Avatar
You can run 33x10.50s stock. I would upgrade your rear coils, bj spacers, remove swaybar front and rear, and new shocks. That's a good nice clean lift to keep you going and wheel some 33s successfully. I have seen people run everything from 31x10.50s to 35x10.50s with this setup. You can always add fiberglass fenders to the front for extra clearence.
Good Luck
Old May 7, 2007 | 04:16 PM
FredTJ's Avatar
Thanks
Why 4" ??
Tell us what sized tires you want to run and what type of off road terrain that you plan on running.
If this is just for looks, then that's a different story.
Fred
Old May 8, 2007 | 07:28 AM
norcalsvx's Avatar
total chaos is the way to go for long travel
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Road Bull
Oct 10, 2015 04:55 PM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
