1987 Toyota P/U Slave Clutch Cylinder Install Question
Old May 20, 2020 | 04:51 PM
jb9's Avatar
jb9
Hello,
It's been a while since I have posted (I'm homesteading and it's been hectic).... Anyhow, my slave clutch cylinder just went on me and I need to replace it. I have the Aisin part in hand and I have been watching a couple videos. I found a video that suggests a dab of grease on the push rod and around the boot seal. In the video, the (very knowledgeable) fellow pulls the boot and takes care of this. Why couldn't I pull the push rod and boot assembly to give myself a little more room for the hard line threading process (the part that causes all the brake fluid to pour down your arm).
I have successfully loosened the mount bolts on the bell housing (22R) and used my line wrench to get the flare nut to move as well (AeroKroil is the most amazing product in the world). Anyhow, I'm ready to go with this but I wanted to ask the forum for thoughts. I have a rubber vacuum line cap for the hard line too.
I was thinking about this.
-loosen mount bolts
-remove flare nut
-remove mount bolts
-quickly put rubber cap on hard line (fluid pouring down my arm)
-remove old slave cylinder
-clean area
-install new slave cylinder (without push rod)
-thread flare nut being very careful
-install mount bolts
-tighten flare nut
-tighten mount bolts
-slip push rod into slave and against transmission plate
Does this seem like a dumb idea?
Thanks in advance for any thoughts. Wish I had enough money for a new truck but it's all going to the lumberyard right now.
jb9
Old May 21, 2020 | 02:48 PM
Mr. Z.'s Avatar
I wouldn't take apart the new slave cylinder.
When I installed a new slave while overhauling the clutch system, the cylinder went in without any drama.
install, bleed, done.
Cheers
Old May 25, 2020 | 09:33 AM
jb9's Avatar
jb9
Thanks Mr. Z and old87yota. I am about ready to do the swap but I am confused by something. The slave has all the leakage indicative of the failure so that's all good. The bolts are ready to go. Is there a possibility that the clutch release arm/pad that is pushed by the rod has a return spring that is broken or not working? When the truck is completely off (not started), I can shift into gears without depressing the clutch. When I start the truck and the engine is running and the vehicle stick is in neutral, I can't pop it into a gear. When the truck starts, does the clutch release arm/pad become engaged and move toward the slave cylinder rod? I am concerned that either I don't know how the slave cylinder works or there is a problem with the arm or the transmission.
There is no fluid or anything around the clutch release arm/pad/boot.
I also only ask this because I tried to move the clutch release arm/pad myself and I couldn't move it (thinking it was either too hard to move or it simply doesn't really articulate past more than 10-20 degrees.
Old May 25, 2020 | 02:15 PM
Mr. Z.'s Avatar
The slave cylinder push rod engages the clutch release fork.
This has the throw-out bearing on the end.
Are you replacing the clutch?
Have you looked through the FSM?
Here is a link to the clutch section.
https://cardiagn.com/clutch-86-89-4runner/
Old May 25, 2020 | 06:11 PM
jb9's Avatar
jb9
Well, I managed to get the new slave cylinder installed. I didn't even lose that much fluid. I threaded the hard line flare nut first for what it's worth...
The truck appears to shift fine but I am still concerned. Not much movement from the clutch release fork from what I can see. It may have always been this way but it is perplexing. I did a short drive today to fill my 5 gallon water jug. This is the last thing I need!
I wish I could see the rod moving that clutch release fork a little more... Thanks for staying on this thread you guys. I'll look at it again tomorrow.
4x4 YOTABOY 4X4
Nov 10, 2009 06:27 PM
dem0nk1d
Dec 21, 2008 10:31 AM
86 yota
Jan 18, 2007 02:49 PM
AKennedy87
Jan 8, 2006 02:25 PM
