1987 toyota 4x4 how to get wheel bearing nut off??????
Old Oct 7, 2014 | 07:56 PM
YotaGirl85's Avatar
So I'm changing my rotors. Got everthing apart. I turned the wheel bearing nut a couple turns and now its getting tighter? Am I doin somethin wrong or with all the crud is it jammed? I'm confused any help greatly appreciated. Thanx
Old Oct 7, 2014 | 08:13 PM
Gizler00's Avatar
Should be an external retaining clip on the axle in all that gunk. Your nut might be tightening against that if you did not remove it.
Old Oct 7, 2014 | 10:26 PM
scope103's Avatar
There is a lock nut and an adjusting nut. http://personal.utulsa.edu/~nathan-b...15componen.pdf You must first open the lock washer, remove the lock nut, and then remove the adjusting nut. If you start turning the lock nut without doing the rest, you'll just turn the pair of nuts until they jam.
Old Oct 7, 2014 | 11:46 PM
wyoming9's Avatar
Red face
Sometimes over the course of it`s life the threads may have been damaged as the nut starts to come off.
I have seen this quite a few times if all the above have been done.
Old Oct 8, 2014 | 04:19 AM
Gizler00's Avatar
Originally Posted by wyoming9
Sometimes over the course of it`s life the threads may have been damaged as the nut starts to come off. I have seen this quite a few times if all the above have been done.
X2 on this. There have been plenty of times that I had to use my hub socket with a ratchet to get it off as the threads were damaged. And other times, I was able to simply turn I off
arlindsay1992
Jan 23, 2024 01:34 PM
91toybeater
Dec 27, 2015 07:46 PM
AustinTaco
Jun 21, 2015 09:54 AM
