Strange starter issue
Old Oct 5, 2007 | 08:23 AM
patallen's Avatar
So my 85' 22rec was not starting until i knocked the solenoid with the extention for the jack...
So i replaced it with a rebuild unit...same thing.
I replaced it again with a NEW unit...SAME THING !!!!
what is going on with this starter...i opened it all to see what was going on, nothing aparent.
I am getting full power at B+ and solenoid when it dont want to crank so its the starter itself. I was wondering about the body of the starter not beign grounded but it is not since the engine block has been rebuilded and painted.
I can hear a small "tic" but nothing else. I realised that it need a very small tap on it and then it goes...
argh !!!
any idea ??
Old Oct 5, 2007 | 10:02 AM
WI_Mike's Avatar
I had this problem on my trip from Milwaukee to Salt Lake City recently. This issue happened two times when we stopped for gas. I think that there is a problem where the vehicle doesn't know it is in park and therefore won't send power to the selenoid. Make sure you are all the way in park and try to start it.
Old Oct 5, 2007 | 10:11 AM
patallen's Avatar
sorry but re-read my post, i have +12v at the solenoid and the B+ and i hear a "tic" inside the starter when it dont want to cooperate.
Old Oct 5, 2007 | 10:43 AM
4Crawler's Avatar
You might want to open up the starter solenoid to see what it looks like inside. Just because you put a "rebuilt" starter in there, don't assume it is all brand new inside, often they are not:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Then try bench testing it outside the vehicle. Put a 12v battery charger or jumper cables off you battery to the solenoid. See if it pushes out and retracts smoothly. And for the grounding question, measure voltage from starter body to battery "-" terminal to see if you have any voltage present there (should be none). And when you measure 12 volts to the solenoid, is that under load?
Old Oct 5, 2007 | 11:10 AM
patallen's Avatar
Be assured, i dont assume anything because i put a rebuild one, what bugs me is that i put a new one and it does the same...
I have around 10v (not 12) at the solenoid under load, but no crank. I believe this is "normal" considering the size of the wire and the path it makes to reach the solenoid.
I did try to jump it directly to the battery to get a healty 12v but still no workie. Only the litle tap on it does it.
There is no voltage drop across the body of the starter nor the engine or the battery.
btw, i am automotive electronic engineer, so i know my stuff unless something play funky like this
EDIT: it happens very not often, so i test benching it can take forever until it will do it.
Old Oct 5, 2007 | 11:36 AM
4Crawler's Avatar
10 volts under load is not normal, at least if the starter is not working. Much more than 0.5 volts drop from the battery is too much:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Solenoid pulls about 20 amps so you need a good connection to make it go. Check upstream from the starter to find out where the voltage drop is coming from:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Oct 5, 2007 | 11:44 AM
patallen's Avatar
i did try to jump it directly to the battery and it was not working either.
there was 12v then.
btw, nice link for the starter bogus info.
I have many old DVOM, i will connect them to the system (B+, solenoid, body to the engine) and will look when the problem will happen...maybe it is just inards.
Old Oct 5, 2007 | 11:59 AM
patallen's Avatar
is there a start relay only on manual ones?
mine is automatic.
Old Oct 5, 2007 | 12:03 PM
4Crawler's Avatar
mine is automatic.
Maybe yes, maybe no. I think they started around '86 or so with the clutch cancel switch. My '85 has none. No matter w/ relay or not, the power for the relay (if present) and the solenoid comes through the ignition switch. Sort of a strange arrangement, as the relay really does not do anything to take the load off the igntion switch.
ghostmoney
Jan 28, 2018 11:42 AM
theking11863
Mar 19, 2016 09:36 PM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
