steering wheel removal
I've looked for 3 days on here and am having trouble finding info/post/threads on steering wheel removal and headlight combination switch removal.
Will some one show me some links on this please?
Thanks,
slowboy
1985 Toyota 4x4 DLX P/U
Thanks,
slowboy
Thank you so much!!
That's exactly what I needed...Great video!!
I've read online, maybe on YotaTech where sometimes if the low beams don't work try filing contacts on combination
switch...you wouldn't know how to get to the lowbeam contacts would you?
That's what started all of this. The low beam headlights work sometimes, and sometimes they don't.
When they don't come on the highbeam indicator comes on, on the dash. When lowbeams work the indicator isn't on.
The highbeams work fine. The relay under the hood is good. I bought a new one just to be sure that wasn't the problem.
Thanks again,
Keith [slowboy]
Thanks again,
Keith [slowboy]
As I recall, it's just a matter of removing the top and bottom covers of the steering column. Switch contacts are right out in the open.
Don't use a big rasp type file. If possible, just use some very fine sandpaper, Ruby Cloth, like that. The less "contact" materiel you remove, the better. Yeah, get rid of the non-conductive crud on the contacts, but that's the most. For very slightly corroded contacts, a pencil eraser will do the trick.
Also, some of them get slightly bent out of shape, and just need to be bent slightly back into the proper position to make contact when they should.
Finally, a little dab of silicone dielectric grease can have a very beneficial effect on contacts, and plug pins.
Good luck to you!
Pat☺
Good luck to you!
Pat☺
I would try cleaning the contacts (WD40 and/or Electrical parts cleaner) with a thin cloth before filing. Filing would remove material and you may lose the connection completely.
Thank you so much!!
Thanks again,
Keith [slowboy]
Thanks again,
Keith [slowboy]
I did spray electrical parts cleaner where I could reach and after a few minutes I sprayed out best I could with an air hose.
I've been driving truck with lowbeams on today to see how it did and so far lowbeams come on and stay on until I turn them off.
How long it'll last is yet to be seen.
I haven't put steering column covers back on incase I need to remove combination switch.
Probably should still clean contacts for combination though.
Thanks,
Keith [slowboy]
Thanks,
Keith [slowboy]
H4 Headlamp Relay Wiring Harness
Headlights H4 Wiring Harness Headlight Relay Kit For Toyota 95-97 Tacoma 88-95 Pickup Fix Dual Ground Problem
I could very wrong but I think it's the same thing.
This is where I got the information:
https://www.yotatech.com/forums/f131...w-pics-235789/
Good luck to you!
Pat☺
Good luck to you!
Pat☺
let me know if picture shows...still not sure if I'm posting pictures right.
Thanks,
Keith [slowboy]
There's a picture of the switch that controls the head lights. High beam, low beam, and flash.
Essentially, you can look at the switch contacts, and if it's not high beam or flash, it's low beam. It's a pretty simple switch. Be careful not to loose the little ball bearing at the base of the shaft of the handle where it comes into the switch. You can clean the contacts as I described. Be sure NOT to bend the contact's metal strips, that hold the contacts. Also, make sure those same strips aren't bent by repeated use.
Does that help?
Pat☺
Does that help?
Pat☺
I put new combination switch on and everything works except for the high speed setting on windshield wipers. It's like low speed whether on high or low.
Any suggestions please?
Thanks,
Keith [slowboy]
Thanks,
Keith [slowboy]
BFA
Dec 20, 2016 10:13 PM
yotiegurl
Nov 23, 2010 11:14 PM
