Steering Box Rebuild
Old Aug 21, 2006 | 09:34 AM
4Rocker's Avatar
Has anyone rebuilt the power steering gearbox from their 84 or 85 4Runner or pickup? Mine has started leaking out of the input shaft seal and so far I have removed it from the truck and removed the 4 bolts that hold the worm gear shaft in. Does anyone have experience rebuilding these or have a FSM or diagram that shows how the rest of the box comes apart? I can get a new seal kit from toyota for about $120, or worst case scenario a rebuilt steering box for about $350.
Old Aug 21, 2006 | 09:46 AM
seaflea's Avatar
here is a post on modifying the box for hydro assist. it has a lot of good info in it and should help you to at least take apart the box and get things back together.
http://board.marlincrawler.com/index...7310#msg107310
Old Aug 21, 2006 | 10:59 AM
BLKNBLU's Avatar
http://www.trademotion.com/partlocat...=8&catalogid=1
This is sort of a pic... kinda
Old Aug 21, 2006 | 12:25 PM
4Rocker's Avatar
Sorry if i didnt specify earlier, this is for an 84-85 model, meaning solid front axle with the push-pull steering box, not the 86-up IFS box. Thanks for the replies though.
Old Aug 21, 2006 | 01:02 PM
surf4runner's Avatar
nice link seaflea.
no mention of fluid to use. [w/o power steering] i heard that using a (thicker) synthetic gear oil w/molybdenum? or MOLY_G is also good for the box parts.
Old Aug 21, 2006 | 03:20 PM
seaflea's Avatar
Originally Posted by surf4runner
nice link seaflea.
Thanks. Although, I wasnt paying attention to the location of this thread.
Sorry, I dont have any information on the non IFS box.
Old Aug 22, 2006 | 05:14 AM
4Rocker's Avatar
I was able to locate a complete PDF of an 85 4Runner FSM. Thanks for the help! I know the 84-85 steering setup isnt very common and theres not a whole lot of info out there about it. A seal kit and it should be ready to roll by the end of the week!
Old Sep 8, 2011 | 08:29 AM
4Crawler's Avatar
Originally Posted by estrada.1977
I have an 85 4 runner and I want to do a hi-steer, what model and year of 4 runner or toy steering box fits in this truck.
there's a 95 4 runner that I can get the steering system and brake system (master cylinder and booster) from it.
That will work, anything 4WD from '86-'95.
Old Sep 8, 2011 | 11:01 AM
BigBluePile's Avatar
IIRC, 2wd steering boxes(nonpower steering) use gear oil....the IFS boxes and SA push pulls(power steering equiped) use ATF.
Old Sep 9, 2011 | 09:09 AM
Staceman1's Avatar
Just replace the seal on the screw-on disk for the input shaft. I had to do it to mine...
Old Sep 9, 2011 | 09:24 AM
Staceman1's Avatar
P/S Worm shaft seal,
NAPA part number "NOS7007" or just 7007
Old Jul 4, 2014 | 08:33 PM
sea dawg's Avatar
I'm getting ready to lift my 85 Toyo Extra Cab, and was told that when I convert it to high steer, I'll need to put a steering box from and IFS on it. I'm guessing that when I find a used one, it'll likely need rebuilding if possible.
Any suggestions on how to proceed??
Old Jul 4, 2014 | 09:07 PM
4Crawler's Avatar
Buying a rebuilt one is probably a good way to go. DIY rebuild write-up below:
- http://web.archive.org/web/200605150.../taco/box.html
Old Jul 5, 2014 | 08:28 AM
sea dawg's Avatar
Thanks much for the tip. Sounds like I asked in the right place!!!
jerusry
Oct 19, 2015 05:28 PM
delmert
Sep 30, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
gillesdetrail
Aug 3, 2015 04:43 PM
bobpat
Aug 1, 2015 09:25 PM
