SR5 gauge cluster swap problem
Old Dec 5, 2010 | 11:24 AM
hiltu's Avatar
Well it seems everyone has had problems with the cluster swap, mine being insignificant to others, but none the less annoying. First the parking brake engaged light doesn't work (it did on the delux gauge). Also it seems like the oil pressure might be low. At idle it sits at one line above the lowest line. Any chance for a fix for the parking brake light?
Old Dec 5, 2010 | 05:17 PM
yotaman90's Avatar
Did you replace the bulbs?
Old Dec 6, 2010 | 06:04 AM
hiltu's Avatar
No, all the other bulbs work. The battery light, the check engine light, 4WD light, High beams light, and all the gauges light up. No bulbs appear to be out. Seems like the parking brake bulb is burnt out than?
Old Dec 6, 2010 | 07:28 AM
Junkers88's Avatar
Sounds like the bulb is out, pretty easy to check.
As far as the oil pressure goes did you swap out the sending unit?
Old Dec 6, 2010 | 07:44 AM
yotaman90's Avatar
Do you have a picture of how high the oil pressure gauge reads with the engine running? Also, the bulbs being burnt out in used gauge clusters is pretty common. One of the bulbs was burnt out in my clinometer as well, and I didn't find out til I already had it installed
Old Dec 6, 2010 | 09:00 AM
hiltu's Avatar
Yes I replaced the oil pressure sending unit with the proper one. I don't have a picture, but it sits at basically the "1/4" mark at idle. Im going to see about replacing the bulb(s). I also have the inclinometer to install.
Old Dec 6, 2010 | 11:39 AM
myyota's Avatar
About the 1/4 mark is were my oil gauge reads, so that`s about normal.
Old Dec 8, 2010 | 05:50 AM
hiltu's Avatar
thanks myyota. Replaced the light bulb for the parking brake and it now lights up. Also there is a slot for a bulb for "oil at temp". If you put a bulb in there it will render the oil pressure gauge inoperative.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coryc85
Sep 9, 2015 06:24 AM
Cplmike
Jul 8, 2015 08:47 PM
