Ring and pinion
Old 01-17-2010, 09:36 AM
rednecktruck22's Avatar
Ring and pinion
I have a stock 1985 pickup. The truck had 30's on them i did put 33x12.5x15 and maybe plan on putting put 35's on later. should i stick with my gears now or should i go get diffrent ones and what one's should i get.
Old 01-17-2010, 10:23 AM
camo31_10.50's Avatar
Search young grasshopper.....this gets covered about 15 times a day lmao..
33's are nice with 4.88's
35's are nice with 5.29's
if ya wanna you can go with some 5.71's...but it'd be best to have em treated so they don't end up breakin lol
Old 01-17-2010, 11:21 AM
is it ok if i have 5.29's on when running 33's
Old 01-17-2010, 11:24 AM
waskillywabbit's Avatar
5.29s are too much for 33s imo.
Old 01-17-2010, 11:29 AM
Etype R's Avatar
I feel that 4.88s are better for 35's and 4.56 gears for 33's. Its a bit of personal prefernce and if you want lower rpms on the highway.
Old 01-17-2010, 11:31 AM
why would it be too much
what would happen
Old 01-17-2010, 11:33 AM
its not going to be drivin on the hwy it just going to be straight mudin truck
Old 01-17-2010, 11:59 AM
grant526's Avatar
I'm running 5.29s with 33's, until I wearout the 33s and can upgrade to 35s.
It's Definitely Torquey with this set up. But I wouldn't recommend it for a DD. Not to mention its taching like 4000 at 70 mph (actual) reading about 79 on the speedo.
I ran 31s with stock gears and was about 10% over geared. I ran these 33s with stock 4.10 gears and was about 14% over geared. Now, running 33s with 5.29's, I figure about about 14% undergeared. It's definitely torquey, but not fast. I'm looking forward to trying 35s with these gears.
I haven't had a chance to trail ride it since installing the gears. But I'm stoked to this spring. : )
Good Luck with it!
Old 01-17-2010, 12:04 PM
grant526's Avatar
Sorry. Double post
Old 01-17-2010, 02:58 PM
the truck is just for mudding not a DD
What would be best to get for it running 33's
Old 01-17-2010, 03:06 PM
yoder519's Avatar
it was answered in your first post!!! geez your gonna have to do a little searchin yourself or people r gonna stop answerin your questions that are covered all the time on here
Old 01-17-2010, 03:13 PM
Etype R's Avatar
If it is off road only, and your not crawling in the rocks. Then why do you need to regear? The 4.10 gears have a stronger pinion then 5.29's. You need wheel speed and HP for mud. Pop it in low range and have at it
Old 01-17-2010, 03:23 PM
but i just thought i would have to change it but if 4.10 is good for 33's then i'll leave it because it does drive good and play good just thought diffrent gears would make a diffrents
Old 01-17-2010, 03:56 PM
well..you could pop it in 4lo and 2nd gear and it's about the same as 4hi and first..( a little slower actually..but not much) i rarely use 4hi anymore..i'm in either 4lo and 2nd or 3rd LMAO
Etype R's Avatar
If your happy with it, no need to change it
Most of us are into crawling, and need the lower gears for the rocks.
Old 01-17-2010, 04:07 PM
Lysmachia's Avatar
Also if you do re-gear it will depend if you have manual or auto. I can get away with 5.71's and 35's when tippy was running because she was auto and her tall overdrive made it work perfectly.
Anyway yes please earch a little more.
Old 01-17-2010, 08:24 PM
When i go muddin i use 4hi and 2nd. When i try to put it in 4lo then tuck would not really move all so much
The truck is Manual
kawazx636
10-06-2021 03:03 PM
dzldust
7
10-06-2015 05:39 AM
hiluxinargentina
09-30-2015 05:51 PM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Quick Reply: Ring and pinion
