Remove or Replace Catalytic Converter
Old Oct 25, 2013 | 07:59 AM
250000_yota's Avatar
Originally Posted by redbayredneck
If they're worth 50 hp, then the Dukes of Hazzard sticker must be worth 150 hp right?
Na, that's like automatic win levels of power.
Like pullin up to a top fueler on Vespa...
Old Oct 25, 2013 | 08:07 AM
redbayredneck's Avatar
Then I just don't understand why my 22RE won't beat my I-Force in a drag race
Old Oct 25, 2013 | 09:14 AM
I'm gonna go with operator error...
Old Oct 25, 2013 | 01:26 PM
REDYOTA's Avatar
Drilled holes in air box 25 hp
k&n filter 25 hp
egr delete 25 hp
Gutted cat 25 hp
Royal purple oil 10 hp
Intake silencer removal 10 hp
disconnected ac belt 5 hp
ngk plugs 10 hp
Advanced timing 10 hp
Mid grade gas 10 hp
Flowmaster 40 hp
Sea foam treatment 10 hp
Thats all they did to the farm truck and it runs 10's
Old Oct 27, 2013 | 06:28 AM
  #25
jssgbsn's Avatar
I figured this question would get a lot of different responses.
What have I done???
Old Oct 27, 2013 | 07:07 AM
  #26
combatcarl's Avatar
What have I done???
Lol. I've not had a catalytic converter on my dead stock 22RE as long as I've had it. And I know it hasn't had one since 97. I know, I pollute. When the new exhaust goes in, it'll get one. I'm sorry, (no, I'm not) you will NOT gain or lose power by removing your cat. It does ZERO to affect you A/F ratio. The only time you'll see a difference, is if your cat is plugged. Fwiw, don't drive around with cats on your exhaust. Of course that's going to stink. (Had to say it, all I could think of while reading). OP, just replace with a high flow cat. If FL ever puts in smog, you won't have to worry about it.
Sent from my NSA screened iPhone using YotaTech
Old Oct 27, 2013 | 07:44 AM
  #27
SoCal4Running's Avatar
Like posted earlier a Cat is not going to hurt performance at all. Not even 1 HP as long as you maintain your vehicle properly.
It you replace it is up to you...
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
skoti89
Jul 8, 2015 12:05 AM
ItsJustD
Jul 7, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
