randomly dies?
Old Feb 21, 2009 | 08:42 AM
sr5yota84's Avatar
randomly dies?
i have got an 84 pick up sa with the 22r. I just rebuilt carb. I wil be driving while its on choke then when it kicks off choke and i push in clutch it dies. Then its a PITA to start again.. And then it will usually do it one more time then it will be good. Any ideas?
Old Feb 21, 2009 | 08:48 AM
algranger's Avatar
I dont think you can be driving while it's on choke.. when you touch the throttle the choke should disengage
Old Feb 21, 2009 | 08:53 AM
sr5yota84's Avatar
ok while its on high idle. and then it will kick down to normal idle(if it doesnt die) around 180 degrees
Old Feb 21, 2009 | 08:57 AM
algranger's Avatar
Oh i see, i didnt realize it was still cold in that case it could be staying on choke
Where is your idle speed set for when your off the fast idle?
Old Feb 21, 2009 | 09:00 AM
sr5yota84's Avatar
about 1100rpms... It seems like the truck is loosing vaccum or somthing. I can keep the truck running and it seems to runn better but it wont idle at that point. Then I rev it to about 4000rpms and it does fine..?
Old Feb 21, 2009 | 09:10 AM
algranger's Avatar
Are you saying you rev it to 4k and it idles fine after that?
Old Feb 21, 2009 | 02:31 PM
sr5yota84's Avatar
Yes. I will rev it up around 4000 rpms and it seems to do fine after words.. There are times as well that i turn it off and start it up like 5 min later and it wont idle.. I have no idea whats causing it. I was thinkin accelerator pump or egr valve but i dont know..
Old Feb 22, 2009 | 09:16 AM
84toylover's Avatar
I was having a similer problem with my 84 22r. It would be fine while cold then say after turning off and starting again it would run really bad and die like it was running on 3cyl. Turns out I had a bad cap, maybe cracked, would get water in there I think just condensation but changed that and no problem now. Also had riched up the mixture because of emissions problems.
These are just some suggestions, I think sometimes we immediatly think "carb problem" but often it's an ignition problem.
Good luck!
Old Feb 22, 2009 | 11:16 AM
sr5yota84's Avatar
Good luck!
Yea i have a new cap and rotor.. I am starting to think coil issues or there is somthing in my float bowl clogging. IDK yet hmmm its getting worse tho!
Old Feb 23, 2009 | 10:57 AM
84toylover's Avatar
By the way you have the same tire combo I had for years and wheeled the p!$$ out of it just the way it was. I wish I still had those tires!
Old Feb 24, 2009 | 06:45 AM
sr5yota84's Avatar
Yea they are great tires.. The only issue i have is they pack with mud/snow really easy..
Old Feb 24, 2009 | 04:07 PM
Alaskan Yota's Avatar
I was having this issue on my 82 recently, it got progressively worse the more often I would drive. If the truck sat for a few days it would run great but after driving for 4 days it was doing just as you described. I rebuilt my carb and put a new intake manifold gasket on and it has driven 60 trouble free miles today... tomorrow or the next day i'll find out if it's really fixed. I also threw some new plugs into her and put on all new vacuum lines.
When was the last time you did a carb rebuild? If it's been 20K miles or more i'd look into it.
I'll post in a few days and tell ya if it fixed the problem.
Niko
Steven.m.paulk
Jun 7, 2020 10:45 AM
Chicken12
Oct 14, 2015 03:54 PM
shredder4286
Oct 1, 2015 01:09 PM
Shagool22
Sep 28, 2015 07:53 PM
Rcbc92
Sep 26, 2015 03:00 PM
