Polished Knuckles?
Old Dec 15, 2006 | 06:22 PM
bear92's Avatar
Polished Knuckles?
I am doing a SAS and was wondering if anyone has herd of Polishing the knuckles before placing them back on?? sounds weird but i dont know.... thanks
Old Dec 15, 2006 | 09:13 PM
4Crawler's Avatar
I sanded out the rough spots on mine and got them pretty smooth. Seemed to help the knuckle seals/wipers stay leak free while I ran that axle. Probably can't hurt anything.
Old Dec 16, 2006 | 08:08 PM
bear92's Avatar
do you have any tips on how to ... what grit any special way........
Old Dec 17, 2006 | 09:15 AM
4Crawler's Avatar
It was about 8 years ago I did mine, so no specific details that I recall. I think I used 2 or 3 of the sand paper discs in my angle grinder, maybe 60-100-120 or whatever they had then used a palm sander with finer grit emory cloth in it to smooth it off. If there are deep pits/grooves, some folks fill with JB Weld or similar and smooth that off rather than trying to sand all the way down.
Old Dec 18, 2006 | 03:44 PM
bear92's Avatar
sweet ......thanks dude
Old Dec 18, 2006 | 04:35 PM
Robinhood150's Avatar
By polishing the knuckles, you mean the balls on the end of the axle housing, right? Because that's what Roger is talking about.
Old Dec 19, 2006 | 06:31 AM
titicaca's Avatar
yea at first i thought he was talkin about building a mall crawler.... i used my palm sander and then i hit it with emery paper.... the epoxy method made me a little nervous but i bet it would work ok i guess.
ive heard of people using epoxy primer and clear coat also...
Old Jan 11, 2007 | 09:45 PM
vwfastg60's Avatar
Sounds like a good idea.Id think you wouldnt want to take too much off cause it wouldnt seal right. I think i may do mine when i get the old front axel off. I have done cosmetic polishing so i will be doing it that way. Any good places to get a frontend rebuild kit?
Old Jan 13, 2007 | 06:36 AM
Aaronb's Avatar
i just hit mine with a wire wheel, shined it up pretty good
ladybugRC
458
Aug 21, 2020 10:41 AM
Firefightersink15
Nov 23, 2015 10:32 PM
stanz
Oct 30, 2015 10:33 AM
sonorn67
Sep 19, 2015 05:39 PM
MudDr
Sep 12, 2015 01:47 AM
