22ret exhaust/DP
Old Sep 28, 2006 | 06:15 AM
kou xiong's Avatar
22ret exhaust/DP
Just curious if theres any aftermarket down pipes for the 22ret 2wd! I did a minor search but nothing so thought it might help if I ask. LMK thanks
Old Sep 28, 2006 | 10:41 AM
Bill's Avatar
Google Jeff Mosk(I think that's his name anyways). He seems to be the be all end all tech guy of the 22RTE. his is putting out somewhere int he neighbor hood of 260hp. I'm positive I remember a link on his site to a guy that sells after market downpipes(with flex joints)
Old Sep 28, 2006 | 02:58 PM
kou xiong's Avatar
Cool, Can you provide me the link or a contact #.. thanks for the info.
Old Sep 28, 2006 | 04:31 PM
Bill's Avatar
Bruces 22RTE page is the one with the flex joints for sale
Jeff Mosk is the 22RTE guru
Old Oct 16, 2006 | 06:50 AM
kou xiong's Avatar
Email Bruces and Jeff but never got a respond back. Any aftermarket down pipe out there.
Shoot me an email at koulio_94t@yahoo.com if you can get one.I"m looking for 65-70mm dp..thanks
Old Oct 23, 2006 | 02:24 PM
dcg9381's Avatar
A decent exaust shop should be able to make you one.. the hardest part is the flange.
Old Oct 23, 2006 | 02:28 PM
AH64ID's Avatar
Doesnt LCE have one?
Old Jan 9, 2007 | 11:58 AM
kou xiong's Avatar
Suk! No luck!
I"m in the process of thinking about swaping the stock 22rte turbo to the 86.5-92 7MGTE turbo. Have any of you guys done the swap and did it clear the steering shaft.
Old Jan 9, 2007 | 05:40 PM
dcg9381's Avatar
As stated above, Bruce makes a downpipe for the 22RTE, assuming you can't have it made locally for less.. I built my own.
Check pirate for 7M swaps - seems to be fairly common...
Old Jan 12, 2007 | 07:57 PM
kou xiong's Avatar
Dcg9381
I notice you've done alot of work on your 22rte, awesome webpage BTW.My question is it possiable to used the the Toyota Cressdas 5MGE Throttle and TPS sensor. I notice you have a 5MGE throttle but does it require any fabication or is it a plug and play. Thanks for your time.
Old Jan 12, 2007 | 08:08 PM
dcg9381's Avatar
Originally Posted by kou xiong
Dcg9381
I'm using a TB from a 7M series. I've heard you can use the TB from the 5MGE also, but I've never confirmed. You should be able to use the same TPS - toyota had two types, so don't dump your old one (just in case).
The 5MGE TB will bolt up to the plenum, based on what I've been told.. You'll have to do some port work to get it to fit correctly (55mm hole on the plenum vs 60mm TB). Linkage - I'm not sure.. I used my old throttle linkage, welded up some stops for WOT and idle.
See my "rebuild" link on my website - there are several photos of the 7M TB.
For more precise information on the 5M TB, post to www.celica-gts.com/forums - I think a few of those guys have done it.
Old Jan 13, 2007 | 07:51 AM
kou xiong's Avatar
Cool,
How did the 7M TB fit on your manifold! Any mods. My idea is to have a streetable truck with power that will pass the california smog, so tha AFM is a must have.
You also mention about you upgrading your TB to a Ford. How is your truck running today and anything new you'll like to share with us! Thx for the quick respond.
OH does it matter if it is a 7MGTE or 7MGE
DeathSycthe02
112
Nov 17, 2013 10:10 PM
lbhsbz
Jul 13, 2011 10:23 AM
rippinone
May 7, 2010 08:09 AM
91FREERUNNER
Mar 12, 2009 08:48 AM
khoopes
Sep 24, 2008 11:55 AM
