22RET Conversion Questions
Old Sep 16, 2008 | 07:38 AM
khoopes's Avatar
I am purchasing a 22RET to install in my 88 4X4 X-cab. I need to know if the 22RET will bolt up to my W56 transmission and if there are any major mods I will have to do to the pickup. (Radiator, A/C, clutch, etc..) I have read the turbo had a different tranny but I just need to use the one I have.
Thanks for any help on this topic.
Kris
Old Sep 16, 2008 | 07:43 AM
JamesD's Avatar
Yes it will bolt to your W series transmission. It is still a 22R engine. If you got the motor with bellhousing you can use the V6 R150 trans, if not just use your old bellhousing. If It came with the flywheel, use the Turbo clutch instead of the standard clutch.
James
Old Sep 16, 2008 | 07:44 AM
4Crawler's Avatar
Probably want to go with the 3-row radiator for the turbo, either the 4-cyl turbo unit or the V6 one.
Old Sep 16, 2008 | 01:49 PM
annoyingrob's Avatar
might as well do a bigger exhaust while you're at it.
Old Sep 16, 2008 | 04:09 PM
XtraSlow_XtraCab's Avatar
And a cool blow off valve that makes you think about silent farts?
Seriously, how about a boost gauge? And I'd consider turbo upgrades, head gasket upgrades, so you up the boost a little bit.
Now that I think about it, is there a factory inter cooler you're supposed to have? Can you get away without one?
Old Sep 16, 2008 | 09:22 PM
khoopes's Avatar
Hmm, I read somewhere that you have to change the MAF as well?
Old Sep 24, 2008 | 11:55 AM
mistreatedtoys's Avatar
I have done this swap both ways. Everything will interchange although your wiring harness maybe slightly different, check the fuel injector plugs. The computer works and I recommened using the efi one not the turbo. You will get a higher top end out of it mine would do 100mph.The radiator is different for the turbo as it has a water port on the top. However most all have a flat spot where the plug goes so you can get one put in. The Airflow meter will work but will need adjusted. You can adjust it by removing the top cover and putting more tension in the spring. This is not an exact sience but you o2 sensor will tell you if you are to rich or lean. The spring holds tension on the door.
r3dfish
54
May 16, 2016 10:31 PM
coleypull15
Nov 3, 2015 07:41 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
