NO spark
Old Nov 9, 2009 | 07:34 AM
Andrew666's Avatar
NO spark
My 84 22re EFI is getting fuel but no spark. Will turn over but no fire. Replaced coil, checked battery connection, please help.
Old Nov 9, 2009 | 09:15 AM
toyotabull's Avatar
are you getting power to the coil?
Old Nov 9, 2009 | 12:02 PM
Andrew666's Avatar
I checked. I am getting + power to both poles..Is that okay? I thought one is supposed to be negative
Old Nov 9, 2009 | 12:30 PM
Andrew666's Avatar
The negative post is getting 11.56 DCV and the positive is getting 0.2 DCV..?
Old Nov 9, 2009 | 12:39 PM
awm3tm's Avatar
does your 84 have clutch start saftey switch?
Old Nov 9, 2009 | 12:44 PM
Andrew666's Avatar
I imagine it came with one but it has not been functional since I have owned the truck.
Old Dec 10, 2009 | 03:58 PM
dubs740's Avatar
why would this matter?
Old Dec 10, 2009 | 07:24 PM
jsn_stockard's Avatar
If you have power to the coil you might have got a bad one from the parts store
Old Dec 11, 2009 | 08:03 AM
Toyota_mike's Avatar
Start tracing where the power stops. But at this point I'd put my money on the distributor. It tells the ignitor to send spark to the cap.
Old Dec 11, 2009 | 01:49 PM
83's Avatar
83
Unfortunately when I went through this is was my ignitor. They are expensive. I replaced all the cheap(er) stuff first- coil, distributer...but it was my ignitor. There are diagnostics to isolate what exactly it is, but I don't have that equipment, so I just started replacing stuff...
If it's your ignitor, they unfortunately run about $340, if I remember correctly...
Old Dec 11, 2009 | 04:36 PM
Yes but you can get a used ignitor from $5-$50 depending where you look. I still say distributor.
zytra
Jan 24, 2019 03:16 PM
Kamaloha
Oct 16, 2015 05:13 PM
shredder4286
Oct 1, 2015 01:09 PM
voiddweller
Sep 28, 2015 11:21 PM
Rcbc92
Sep 26, 2015 03:00 PM
