making procomp leafs better
Hi all. This place rules!!!!!!!!!
Ok so I have an 85 4runner with 3" procomp front and 3.5 procomp rears. Basically I went with the 3" front kit with the 4" rear kit and they say it is a 3.5" spring but it sits 2" higher in the rear. I want to raise the front and soften the rear. My plan is to take out the thick bottom rear leaf and put a longer shackle on to compensate for the lift of the bottom leaf. Then I want to put a 3" longer shackle in the front to level it out. My theory is leveling the ride hight and softening the rear will make it ride allot nicer on the road and flex allot more off road with only the cost of making shackles. I have never heard of anyone trying this and would like some imput. Thanks
Just need to make sure that thick bottom leaf does not also serve an anti-wrap function. I went on a run with one guy who did something similar with his pickup, had a really soft and flexy rear suspension. By 3 miles into the trail, those rear springs were bent into an "S" shape and the axle was sitting up against the bump stops.
I ran the 4" procomp leafs front and rear not bad ride but the rear was way to stiff so I mixed the stock rear with the procomp rear and it road great and still gave me lift, as for the front I did the same as you said and added a shackle to level it out
PRODUCT DESCRIPTION
- Progressive Multi-leaf spring packs increases GVW and load carrying capacity without sacrificing ride quality.
- Steel encased, no maintenance rubber bushings eliminates squeak from low cost urethane bushings.
- Bottom overload spring provides added load capacity.
- Tapered leaves for increased suspension travel.
- Oversized Telfon mileage wear pads.
- Permanent angle-correcting degree shims.
- Shot-peened for strength and durability.
- Reduced axle wrap by eliminating rear lift block.
- Allows cost-effective way to replace rear springs and achieve desired ride height.
Ok not that I think any one really gives a rip lol but for the people that do run the prostiffs in the rear I think I might be on to something.
After doing some searching I found out that procomp makes a track bar for the block lifts to control axle wrap. They also sell the same part number for the 1.5" AAL lift, so I think if I have to much axle wrap without the bottom load leaf I will install the 72082B track bar.
So that will be 3" front springs (31221L/31222R) with 5" shackles. 3.5" (33311 more like 5") rear springs with overload leaf removed (1" drop) with 5" shackles and 72082B track bars.
Right now my shackles are at 60* to the frame front and rear so I think with 1.5" longer shackles I should get about an inch of lift out of them.
This is the specs on the rear springs 33311
Flat Length: 48.22"
Free Length: 42.44"
Caster: 9.56
Front Eyelet: 1.25"
Rear Eyelet: 1.25"
Leaf Width: 60mm
Leaves: 4
Weight: 30.84lbs.
Spring rate(lbs/in): 209/310
And the front 31221L/31222R
Flat Length: 45.50"
Free Length: 43.25"L/43.50"R
Caster: 5.62L/5R
Front Eyelet: 1.17"
Rear Eyelet: 1.17"
Leaf Width: 2.36"
Leaves: 3
Weight: 28.14lbs.L/25.76lbs.R
Spring rate(lbs/in) 301
The rear springs have a 4* shim and they are a 5" spring. Dropping the rear 1" by removing the overload and raising it back up with the shackle I should only need a 3* shim, but I might get away with keeping the 4*. I dont think the front is going to be an issue but correct me if im wrong please.
I think I covered everything and I'm not doing this for a while but I like brainstorming and I want to see if i got this right.
Flat Length: 48.22"
Free Length: 42.44"
Caster: 9.56
Front Eyelet: 1.25"
Rear Eyelet: 1.25"
Leaf Width: 60mm
Leaves: 4
Weight: 30.84lbs.
Flat Length: 45.50"
Caster: 5.62L/5R
Front Eyelet: 1.17"
Rear Eyelet: 1.17"
Leaf Width: 2.36"
Leaves: 3
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
Those shackles will add about 1.5 degrees tilt angle that you may or may not need. But best to measure and shaft angles and see:
- http://www.4crawler.com/4x4/CheapTri...n-Measurements
Awesome Thanks. I will be checking angles for sure just to be safe. You da man, man
But now you got me thinking, Why did procomp put a 4* shim in the spring pack and they don't even sell longer shackles thats how they came??????????? Also the pinion is pointed straight at the t-case right now with stock shackles. Hmmm
BTW: Pinion flange should be parallel to the t-case flange with your u-joint shaft, not pointing at the t-case:
muddy: Did you ever get around to trying this? I have the same pro comps and would love to hear how it worked out for you. the ride is soooo bouncy and the shackle has a tendency to flip against the frame if I unload - say, over a speed bump too fast.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
kirkrunner
Jul 27, 2015 07:59 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
