lengthened wheel base 85 yota
Lengthen? Why?
Move the Rear axle back some and the front axle forward. This will give you a longer wheelbase, as well as increase your entry and exit angles.
But you will also need to extend drivelines and probably brakelines too.
Is your bed Bobbed? It looks pretty short in you avatar.
But you will also need to extend drivelines and probably brakelines too. Is your bed Bobbed? It looks pretty short in you avatar.
I think it is, but you can figure it out with a tape measure.
As far as moving the axle back, You can look around for different springs or have some made the the pin located further back. Or have you considered going to a 4 or more link suspension with coils? That's what I would eventually like to do.
What are you trying to gain by lengthening the wheelbase?
Departure and tire clearance for the 36's I'm getting as soon as I figure out how to clear them and where I wheel I've almost gone end for end too many times I need to shift my weight further back
What did you do about the steering?
Did you keep the springs in the same spot or just move the axle on them?
Do you know if you can just flip the rear springs end for end, and reutilize the factory axle locater pin?
Crossover steering
we drilled new holes 2-3"s forward of the factory hole in the main leaf... very easy to do.
i don't see why one couldn't
Thanks guys I'm going to try flipping the springs and running a extended cab driveline and I'm going to give the drilling a hole through the front springs to move the front axle what did you use for a pin to locate the axle did you have to do any welding? I'll let you know how it works.
like paper thin garbabge... that's the official technical term for it's thicknes
i replaced it last night, patched up the damage from the break on the frame, found some scrap metal that worked great.. it's really, really beefy.. 3/8"s thick!!
anyways, it's all better.. probably withstand an IED now...
-Jason
-Jason
shadowbirdie
Jul 21, 2015 10:38 PM
