leaks on the inside!!
Old Dec 7, 2007 | 05:43 PM
84yota4x4's Avatar
Exclamation leaks on the inside!!
so my clutch master was leaking on the inside pretty bad...and i replaced it and now its still leaking but not half as bad as before..why would it still leak? i wanna durabak my interior but i cant get it to stop leaking! any ideas?
Old Dec 7, 2007 | 06:24 PM
84yota4x4's Avatar
anybody have any advice?
Old Dec 7, 2007 | 06:26 PM
DeathCougar's Avatar
you replaced the clutch master cylinder? With a new one, or a used one?
Old Dec 7, 2007 | 06:27 PM
84yota4x4's Avatar
with a new one
Old Dec 7, 2007 | 06:31 PM
hmm. if you have the clutch rod adjust too far out it can pull it past the seal, and cause leaks. Check that.
Old Dec 7, 2007 | 06:47 PM
84yota4x4's Avatar
how far should it be adjusted? i turned it like 3 or 4 times. should it be shorter or longer?
Old Dec 7, 2007 | 08:41 PM
it should be adjusted out til you get full pedal range. If its engaging es soon as you TOUCH the pedal, its too far out.
Old Dec 7, 2007 | 08:50 PM
84yota4x4's Avatar
ok i will give that a try. thanks for your advice
Old Dec 8, 2007 | 07:39 PM
myyota's Avatar
It shouldn`t need to be adjusted, you should be able to bolt the new clutch master cylinder in place and be good to go, thats all i did when i replaced the clutch master cylinder on my 84 4Runner. If it still leaks after you get it adjusted properly then your new master cylinder is bad.
Old Dec 8, 2007 | 08:00 PM
drew303's Avatar
can u get a picture?
shouldnt be leaking regardless of where the rod is. take it back and get one from the dealer. dont by aftermarket clutch hydraulics. They suck.
58rennur4
Aug 4, 2015 08:49 AM
PlayAwhile
Jul 20, 2015 11:36 AM
icentropy
Jul 14, 2015 10:23 AM
horunner1x
Jul 10, 2015 06:33 AM
Avenged
Jul 9, 2015 07:55 AM
