Knuckle leaking
Old Mar 6, 2012 | 01:44 PM
grantxurismo's Avatar
Knuckle leaking
hey all
I picked up this yota last fall and having been fixing up a lot of hack jobs from the PO
I'm new to toyotas but have been 4x4in for several years
After coming home from a lot of hard wheeling @ TDS I noticed one of the birfields puking a decent amount of grease
Since only the driver side had a heavy amount it made me wonder if it was normal or not
PO claimed full rebuild within a year ago upon installing TG dirty 30s, but I am now unsure after seeing this
Old Mar 6, 2012 | 03:32 PM
waskillywabbit's Avatar
Nice "pea soup"
Failed axle seal allowing diff fluid and birf grease to mix.
That is your "knuckle" leaking. The birfield is inside of that connected to the axle shaft.
www.ncttora.com/fsm
:wabbit2:
Old Mar 6, 2012 | 03:42 PM
anthony1's Avatar
Get the seal from Marlin....it's the best.
Old Mar 6, 2012 | 08:29 PM
spacecadet's Avatar
dunno, looks like every solid axle front end i have owned
Old Mar 7, 2012 | 03:27 AM
rokblok's Avatar
Maybe you should start replacing those leaking seals..... lol
Old Mar 7, 2012 | 04:25 AM
A properly maintained solid front axle, even a wheeled one, should NOT look like that
:wabbit2:
Old Mar 7, 2012 | 04:25 PM
85sr5yota's Avatar
i just did this repair easy fix and use the ones from marlin it will make life easier
Old Mar 7, 2012 | 06:09 PM
warmonger88's Avatar
I love the smell of a leaking seal!
glowz825
Jan 25, 2022 09:28 AM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Ernie217
Aug 14, 2015 05:25 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
