J arm hitting frame!!!!!!!!!!!!
Old Jan 14, 2011 | 01:05 PM
muddy4runner's Avatar
Hi all. As the title says my J arm is hitting the frame where the bumpstop is supposed to contact the frame. I have the stock bumpstops and surly this is not supposed to happen with stock springs. (I have 3" procomp springs in front) I was driving my drivers side wheel up a snow pile to see how much flex I was getting and my J arm hit the frame. I know that the 2" longer than stock shackles I was testing pointed my pinion down about 2.5 deg so this is a factor but still this should not happen. now I'm starting to think the axle is bent, but it could be the j arm... What do you guys think. Thanks in advance for any input.
Old Jan 14, 2011 | 01:20 PM
4Crawler's Avatar
Picture(s)?
What do the bump stops look like?
Might be the springs are in backwards (assuming they are not a symmetrical design).
Old Jan 14, 2011 | 02:08 PM
The bump stop looks exactly like this one but it says 100 on it and the passenger side one say 90. I'm assuming it means 100mm and the 10mm difference is the difference in mounting height on the passenger side.
http://www.4x4wire.com/toyota/tech/m...p2/image08.jpg
HMM... You got me thinking so I went and measured but it looks like they are the same or close to stock
79-85 Toyota front
Flat length = 45"
Front Half = 22.5"
Rear Half = 22.5"
Width = 2.36"
Front Eyelet = 18mm ID
Rear Eyelet = 18mm ID
and the procomps are
Part # Flat Length Free Length Camber Free Front Eyelett i.d. Rear Eyelett i.d. Leaf Width # of Leaves Spring Rate
31221L 45.50 43.25 5.62 1.17 1.17 2.36 3 301
DeathCougar
Apr 1, 2018 11:29 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
kirkrunner
Jul 27, 2015 07:59 PM
yourrealdad
Jul 21, 2015 11:13 AM
1994toyota
Jul 17, 2015 03:03 AM
