i need all the advice i can get
Old Aug 22, 2008 | 08:52 AM
Over-Rever's Avatar
i found out why my shackle is on the frame on the drivers side and its just what i was praying it wasnt.... the frame
does anyone have any ideas on how to fix it? im all ears
Old Aug 22, 2008 | 09:35 AM
abecedarian's Avatar
Can you get a pic, or more than one, of the whole spring, and the same of the other side?
Old Aug 22, 2008 | 09:55 AM
Over-Rever's Avatar
Old Aug 22, 2008 | 09:58 AM
I was hoping to see how the spring sits on the other end, what type of curve it has, etc. and maybe even that mount from a bit further away.
Old Aug 22, 2008 | 10:02 AM
but I don't think that's the problem. that's why I'd like to see the whole spring.
Old Aug 22, 2008 | 10:55 AM
Over-Rever's Avatar
more photos
Old Aug 22, 2008 | 11:16 AM
yeah, it's looking like that front spring mount is bent
seeing the passenger side gives it away.
Old Aug 22, 2008 | 11:19 AM
scuba's Avatar
found the problem, you've got bungee cord in there
Old Aug 22, 2008 | 11:26 AM
that's the battery hold down
Old Aug 22, 2008 | 11:37 AM
ryantowry_81's Avatar
the way i se it you have two options: repair or rebuild.
1-repair: you can try and get the front hanger strait again by pulling strategicly with another truck or using heat and a BFH (big F'in Hammer) and when you get it to measure out near the other one find some plate and reinforce the whole side. i have chained frames to other trucks and yanked to bend them back before, kinda hillbilly but it works.
2-replace: go buy a front spring hanger from a sas kit or make one and cut off your old hangers and reinforce the bent frame section and make sure the bottom is flat and weld on the new one. this would be a good time to go to longer leafs if you have any ambition to do so. i feel the second would look better and probably quicker but the first will be cheaper just alot more time.
Old Aug 22, 2008 | 05:36 PM
88wildrunner's Avatar
x2
it would be best to put in a new spring hanger. it would be really hard to bend it back into its correct place, plus if it has bent 1 time it probly with bend again, the more it bends the weaker it becomes.
Old Aug 22, 2008 | 05:56 PM
20twinz's Avatar
Also has white walled tires that are turned to the inside... I thought real trucks had white letters on the tires?....
I would go with the replacement option. Much better choice in the long run.
Old Aug 22, 2008 | 07:38 PM
Over-Rever's Avatar
its not just the hanger thats bent the frame is bent
Old Aug 22, 2008 | 07:51 PM
20twinz's Avatar
How does this happen anyways?....
ashamsuddin
17
Jul 22, 2024 03:59 AM
Steven.m.paulk
Jun 7, 2020 10:45 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
