how to tell what gear ratio
Probably, but if not you can check in your driveway. jack the rear end up off the ground. put the truck in neutral. mark a spot on the drive shaft. rotate the tire one time, and see how many times your drive shaft rotates. but i am pretty sure it is a 4.10
Originally Posted by osbornl1
thanks again. also is it normal for my truck to me made in japan (figure since it was over hear it was made here)
I would be careful about going by the axle code with a truck that old. You never know if a PO has changed the gearing already.
Here is another manual way of measuring the gear ratio that doesn't require jacking. I have done it by taping a string to the drive shaft and marking the wheels where they touch the ground (bottom dead center), then drive or roll the truck one wheel revolution and count the wraps of string around the drive shaft and estimate the partal wrap. If the drive shaft spins 4 times plus about a half turn then the gear ratio is probably 4.56:1 and you have 4.56 gears. If the drive shaft spins 5 times plus about a 1/4 turn then you probably have 5.29 gears, etc...
With the one wheel method posted by 4rnr you need to multiply by 2 I think, because one wheel is not turning. I've never used that way
If it's a 4x4, in 1985 there was only one ratio available - 4.10
(Cant say about 2wd.)
In 85, all the trucks and 4Runners were made in Japan, so that one is easy.
No multiplication is needed, locker or no.
Doggone it! You are correct!
I was just chattin with my father (who was a Toyota dealer and truck nut in those days) and one of the mechanics who worked there for about 20 years and none of the three of us remembered that there were some 4.30s. Around these parts we saw very few autos until near the end of the 85 year, the dealership ordered what sold and in those days we bought Toyotas for work, hunting and fishing, etc and wanted 5 speeds, atuos just sat on the lot (yuppies weren't buying SUVs yet..) and as "enthusiasts' we paid little attention to autos (still don't.) So after all these years some details have kinda slid off to the edges....
How to determine gear ratios
Oh, sorry about that. like i said I had a locker when i did it. To answer MT GOAT's question, it is a detroit e-z lock. I love it, very glad i didnt get the detroit locker. I am only running 32's and I have never heard of any one damaging the stock carrier. In fact after my sas i intend to run 35s on the same locker.
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
