Frame Issues
Old Jun 4, 2006 | 07:00 PM
b82ta3's Avatar
Frame Issues
Today i was working on working on my flatbed/box for my truck and when i set it on my truck something just didnt look straight. so i did a little bit of measuring and it seems that at the rear of my frame, right by where the rear shakles bolt on, the passenger side is 5/8ths of an inch lower than the drivers side. however right by the cab its hardly lower at all. is this a big deal? and what can i do to get it fixed?
thanks
Old Jun 5, 2006 | 02:12 PM
darth brian's Avatar
ouch. twisty twisty
u sure you measured it right? did you go to the ground or the tire kuz that would be off if you wernt on a flat surface
Old Jun 5, 2006 | 03:20 PM
b82ta3's Avatar
i measured to the floor but if you set the box im working on on you can tell its off. is there a better way that i should be measuring it?
Old Jun 6, 2006 | 02:28 PM
no your measuring it pretty much the only way you can but make sure your not on a slanted driveway or anything like that. i used to think one of my springs sagged but it was the way my truck sat on my driveway. if its off then... idk man that sucks, either build your box to compensate or put new framerails on it. i cant think of an easy solution
Old Jun 6, 2006 | 05:02 PM
87rustbucket's Avatar
when someone asks if its crooked tell them to look closer. Then smash their curious head right into the frame and see if it still looks crooked to them
Old Jun 6, 2006 | 05:54 PM
wrenchmonster's Avatar
I'd take it to a body shop and see if they can straighten it out and fish plate it for you. If that is the only problem on your frame I'd consider repairing it, particularly if it's just a trail rig.
Old Jun 6, 2006 | 06:18 PM
brownbagg's Avatar
dont know if matters. look at the frame bewteen gas tank and frame, that is a bad rust area, it could of weaken and twisted the frame.
Old Jun 6, 2006 | 06:43 PM
b82ta3's Avatar
i think thats why its off is because it had rusted there or i assume so since there are plates welded on to the frame in that location. Will having the frame bent like it is now be a huge deal? how important is it that have it straightened?
young buck
18
Aug 27, 2018 02:40 PM
gieselman
Mar 20, 2016 04:34 PM
Backcountry411
Jul 24, 2015 08:06 AM
yourrealdad
Jul 21, 2015 11:13 AM
