drag link HELP!!!
Old Aug 6, 2008 | 07:14 PM
eighty5toyota's Avatar
drag link HELP!!!
(85 toyota pick up 4x4) i installed an adjustable drag link n now da right turn is wider den da left. HOW CAN I FIX DAT???
Old Aug 6, 2008 | 08:24 PM
DeathCougar's Avatar
Have it aligned.
Or just check your toe.
DAT is how you feex eet.
Old Aug 6, 2008 | 10:48 PM
Originally Posted by DeathCougar
Have it aligned.
so i can take it to any shop n get aligned or its a do it urself kinna thing?
Old Aug 6, 2008 | 10:54 PM
im sure a shop can do it no problem
Old Aug 7, 2008 | 12:47 AM
scuba's Avatar
this kid 14 ?
wait, Hawaii...there we go
Old Aug 7, 2008 | 03:43 AM
85TurboRunner's Avatar
You don't need to go to a shop, you have to ADJUST the ADJUSTABLE drag link. I had the exact problem, left turns were no problem and the rights were crazy wide. Just play around with it till it works right.
Old Aug 7, 2008 | 04:31 AM
waskillywabbit's Avatar
Adjust the adjustable drag link until it is adjusted to adjust your steering adjustment correctly. Is there a reason you installed this adjustable drag link?
Is English still required in Hawaii?
Old Aug 7, 2008 | 06:15 AM
English? Is that some new form of Ebonics? I don't think I have heard of English before.
Old Aug 7, 2008 | 08:22 AM
Originally Posted by scuba
this kid 14 ?
im 18.
Old Aug 7, 2008 | 08:26 AM
[QUOTE=waskillywabbit;50893265]Is English still required in Hawaii?
YAH WE SPEAK ENGLISH HEA... ONLY DA PURE HAWAIIANS SPEAK HAWAIIAN LOL OTHER DEN DAT ITS ALL ENGLISH
Old Aug 7, 2008 | 08:57 AM
4Crawler's Avatar
On the adjustable drag links, they have one the rod ends set up with the pre-load spring towards the inside end of the link on both ends. In the stock drag link you have one spring inside and one spring outside. Whey does that make any difference you might ask? Well when you turn one direction (like left) you are pulling on the drag link and have solid metal to metal connection for the ball suds on the pitman and steering arm and the drag link. Turn the other way and compress the two springs and now you have no solid connection inside the drag link. So the trick is to crank down on the rod ends of the drag link as tight as you can get them. You can read about how I adjusted mine on the web page below:
- http://www.4crawler.com/4x4/4R_suspension.shtml#PhaseI
With the stock drag link, you have balanced steering left and right because there is always a spring on one end and a solid end on the other end no matter which way you steer. With the adjustable drag link, you either have solid-solid or spring-spring depending on which way you turn. It is sort of a design flaw in those adjustable drag links. They give you two identical rod ends while they really should make two different rod ends like Toyota did for the stock drag link.
This is a writeup for aligning crossover steering but would apply to the stock push-pull steering as well:
- http://www.4crawler.com/4x4/CheapTri...html#Alignment
Basically, center the steering box so it is in the middle of its range of travel the adjust the drag link length to get the front tires straight ahead.
Old Aug 7, 2008 | 04:29 PM
ITS FIX THANX
live4soccer7
May 11, 2016 06:52 PM
SpookyMulder
Nov 4, 2015 11:56 AM
Davebarbier
Nov 3, 2015 03:28 PM
dbollier123
Sep 29, 2015 05:23 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
