Coolant Leak, front of engine
Old Jun 1, 2007 | 05:57 AM
Volcom's Avatar
I rebuilt an 85 22RE to drop into my 84. It only has 600 miles on it but I've got a coolant leak that drips from the front timing cover. I used a new timing cover, water pump, and used the paper gaskets and some sealant when buttoning up the timing chain area. Do you think it's a faulty waterpump? I really don't feel like ripping apart the front of the engine for this leak.
Old Jun 1, 2007 | 06:09 AM
rdlsz24's Avatar
Did you use sealant on the water pump gasket? When I rebuilt my head last winter I used sealant on that gasket and it leaked. I asked about it on here, and found out that people have better luck not using sealant on gaskets that are around coolant. I followed that advice and used the gasket dry and have had no leaks.
Rob
Old Jun 1, 2007 | 09:29 AM
Volcom's Avatar
Yea, that's my problem then
Old Jun 1, 2007 | 10:19 AM
trousertrout's Avatar
either way if you do use sealant, I let mine sit for a full day to dry/cure to be safe
Old Jun 1, 2007 | 10:57 AM
hodgepodge79's Avatar
X2 give it time to cure. I worked motor assembly at ATK, and we used to finish the motor, throw it in the frame and test-run it. about 1 in 5 would leak from the water pump housing (o-ring and grey thermostat sealant). They began allowing the motor to sit till the next day before install = no more problems.
Old Jun 1, 2007 | 11:00 AM
Volcom's Avatar
Thanks for the tips guys.
Spicer
Apr 7, 2026 07:17 PM
JF9243176
Oct 8, 2017 04:21 AM
voiddweller
19
May 2, 2016 09:10 PM
Vargntucson
Jul 4, 2015 12:15 PM
JF9243176
Jun 24, 2015 04:53 AM
