Which Calipers And Rotors Are These? IFS Hubs?
Old Feb 21, 2023 | 12:58 PM
FourEyes's Avatar
5 Year Member
Hello!
I bought an 84 about a year ago to drive/wheel while fixing my 83. Since then I've developed some braking issues on the front.
The previous owner said that him and his brother did a vented rotor / larger caliper mod at some point. But he didn't remember which way they went about doing it (said his brother just showed up with the parts).
Now that I need to do some work on the brakes that is turning out to be a pain. I've never done the mod myself but I've heard / read that there are multiple possible ways to do this mod and if I remember correctly some even involve swapping over to IFS hubs.
Can anyone identify which calipers and rotors these are?
Also, I doubt he swapped to IFS hubs and these look to be the same as my 83 SFA hubs but I haven't had an opportunity to measure them against each other yet and it may be a minute before I could get to the 83 to do so. Does anyone have a suggestion of an easy way to spot IFS hubs swapped to a SFA? I've never had an IFS truck so not sure what to look for.
Thanks in advance for any help,
Sam
Whole assembly with 2" spacer attached, PO removed the rock guards.
Caliper outside
Caliper back (I know, the clip was dragging)
Caliper inside
Caliper stamp
Rotor thickness
Rotor hub attachment / measurement
What a great helper...haha
Old Feb 21, 2023 | 07:57 PM
aztoyman's Avatar
The typical swap back then was to just use the V6 (3.0) calipers and rotors. Your hubs are just the straight axle hubs with a spacer. The IFS hubs put the wheel mounting surface out further. I just looked up an 88 pickup with the 3.0 on Rock auto and they show the calipers you have. Casting S12W. They list the rotor specs so you'll have to look. The spacer is typically a 1.5" on each side to match the width of the IFS width rear axles when the IFS guys do a SAS.
The most recent brake upgrades are going to IFS hubs to get rid of the spacers and go to a slip on rotor. Check out Sky's or Front Range Off Road for the kits and info.
I just did the big brake upgrade using one of these kits and I ran into some problems so PM me if you decide to go this route. Some options require larger wheels so be aware of that as well.
I hope this helps. Good luck with your trucks.
Old Feb 22, 2023 | 04:54 AM
rattlewagon's Avatar
IFS rotors dont work on SA axles (different hat depth) , but the calipers do.
That looks like a FJ60 rotor.
Old Feb 22, 2023 | 12:53 PM
FourEyes's Avatar
5 Year Member
Thanks for the replies! This helps a lot.
So it looks like I'm looking at 3.0 calipers and FJ60 (or I've heard 40 also?) rotors then. This jives with one of the methods I've heard about. Thanks for the confirmation. I'll measure the rotor to be sure.
AZ: Yeah, I put the 2" spacers on to get the rim to clear the caliper. The PO had done some sketchy spacing to get the rim to clear (and just barely at that) that left the lug/nut thread engagement much less than I would like. See pics:
Spacer
Not much lug there
Dang that's close!
Old Feb 22, 2023 | 04:42 PM
aztoyman's Avatar
Yep, Rattlewagon is right about the rotors. It's all coming back to me. Years ago I ended up putting T100 calipers and rotors on mine and a dual diaphragm booster from a third gen pickup. The booster made a big difference.
Old Feb 28, 2023 | 06:36 AM
Found some good info on accident and through of this thread.
" rotors from a 1981-87 FJ60, or a 1981-83 FJ40 will work. there are a few companies making rotors that have the applications wrong in the catalogs, you want to cross this raybestos#9838 or beck arnley#0832028 "
FourEyes
Feb 28, 2023 04:57 AM
1986YODA
Jan 3, 2013 09:46 PM
lastname_firstname
Jun 27, 2012 01:59 PM
Fix_It
Aug 23, 2011 05:07 PM
Five1Nine8Eight
Jan 14, 2009 12:37 PM
